Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Set up dhcp server on Aruba 5406 switches A and B running VRRP
  • 1.  Set up dhcp server on Aruba 5406 switches A and B running VRRP
    Posted 17 days ago
    Hello.
    I need to make 2 units of 5406 into a DHCP server after configuring VRRP.
    I looked up the manual or example, but I couldn't find it.
    Please help me.
    The configuration is as follows.
    Switch#A
    vlan 2
    ip address : 192.168.2.2/24 vip : 1
    DNS : 8.8.8.8
    Switch#B
    vlan 2
    ip address : 192.168.2.3/24 vip : 1
    DNS : 8.8.8.8
    Thank you
  • 2.  RE: Set up dhcp server on Aruba 5406 switches A and B running VRRP
    Posted 16 days ago
    Hello.
    Both issues seem unrelated to me. The VRRP takes care of presenting one IP address for routing, regardless which device does the actual routing. DHCP on the other hand listens for broadcasts, which both switches will receive. There are several scenarios possible with DHCP, and I am not sure if you can have both switches present themselves to the network as a virtual DHCP server, as you do with VRRP to present a virtual router.
    Would it not make more sense to redirect DHCP packets to a 'real' DHCP server rather than have the switch perform this task?
    TimoRuiter
    timo.ruiter@idemia.com
