SSID connection time AP515, AP505
This thread has been viewed 19 times
  • 1.  SSID connection time AP515, AP505
    Posted Feb 20, 2024 03:28 AM
    hi,
    I'm new working with aruba ap.
    I want to configure a SSID with conection time limit I mean, when an user connects to this wifi network after15 minutes its automatically disconnect from the wifi network
    Is it possible to do that ?
  • 2.  RE: SSID connection time AP515, AP505
    Posted Feb 20, 2024 03:31 AM
    Probably not without external components, like ClearPass. Problem with WiFi is that clients that connect to a network will automatically reconnect when they are disconnected.
    Not sure what you want to achieve with this question, more backgrounds/context may help to suggest something.
  • 3.  RE: SSID connection time AP515, AP505
    Posted Feb 22, 2024 08:34 AM
    You could use windows NPS with their session timeout set to 30 minutes. This post should guide you better.
    https://community.arubanetworks.com/discussion/how-to-configure-session-timeout-and-idle-timeout
    Your aruba implementation type, is it controller based [ do you have an aruba controller ] or controllerless [ Do you have only the AP ]?
    Reach out to your partner if there are other design considerations, there are a lot of factors to be considered.
    /AJ
