Probably not without external components, like ClearPass. Problem with WiFi is that clients that connect to a network will automatically reconnect when they are disconnected.
Not sure what you want to achieve with this question, more backgrounds/context may help to suggest something.
Original Message:
Sent: Feb 16, 2024 04:56 PM
Subject: SSID connection time AP515, AP505
hi,
I'm new working with aruba ap.
I want to configure a SSID with conection time limit I mean, when an user connects to this wifi network after15 minutes its automatically disconnect from the wifi network
Is it possible to do that ?
