SSID not boardcasting
This thread has been viewed 63 times
  • 1.  SSID not boardcasting
    Posted Mar 22, 2023 06:32 AM
    Dear ALL,
    I 'n newbie in aruba, i added the 2 x AP into aruba central, then i create the SSID, but i found the SSID:testing is not boardcasting and the SSID:SetmeUP is boardcasting.
    Anyone can help?
  • 2.  RE: SSID not boardcasting
    MVP GURU
    Posted Mar 22, 2023 07:47 AM
    Have you checked the config audit?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: SSID not boardcasting
    Posted Mar 22, 2023 12:49 PM
    YES, THE  Auto commit state IS ON
  • 4.  RE: SSID not boardcasting
    MVP GURU
    Posted Mar 22, 2023 01:35 PM
    Can you send along similar screenshots like below:
    Dustin Burns
  • 5.  RE: SSID not boardcasting
    Posted Mar 22, 2023 01:46 PM
  • 6.  RE: SSID not boardcasting
    MVP GURU
    Posted Mar 22, 2023 01:54 PM
    Have you tried it using WPA2-Personal? If that works then check to see if you have WPA3 Transition turned on with WPA3-Personal.
    Dustin Burns
  • 7.  RE: SSID not boardcasting
    Posted Mar 22, 2023 02:19 PM
    i changed to WPA2-Personal, but still fail.
  • 8.  RE: SSID not boardcasting
    Posted Mar 23, 2023 12:00 PM
    anyone can help?
  • 9.  RE: SSID not boardcasting
    MVP EXPERT
    Posted Mar 23, 2023 12:03 PM
    Could be a few reasons for this......
    What is the firmware of the APs and the region of the APs (e.g ROW, US?)?
    Have you also set the country code for the APs?
    Did you also assign a radio profile to the APs?
    What is the output of 'show ap bss-table' ?
  • 10.  RE: SSID not boardcasting
    Posted Mar 23, 2023 01:27 PM
    firmware: 8.10.0.5_85552 & AP'sregion: HK
    yes, HK
    No
    d0:15:a6:c4:11:cd# show ap bss-table
    Aruba AP BSS Table
    bss  ess  port  ip  band/ht-mode/bandwidth  ch/EIRP/max-EIRP  type  cur-cl  ap name  in-t(s)  tot-t  flags
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:0
    Num Associations:0
    Flags:       a = Airslice policy; A = Airslice app monitoring; c = MBO Cellular Data Capable BSS; d = Deferred Delete Pending; D = VLAN Discovered; E = Enhanced-open BSS without transition mode; I = Imminent VAP Down; K = 802.11K Enabled; m = Agile Multiband (MBO) BSS; M = WPA3-SAE mixed mode BSS; o = Enhanced-open transition mode open BSS; O = Enhanced-open BSS with transition mode; r = 802.11r Enabled; t = Broadcast TWT Enabled; T = Individual TWT Enabled; W = 802.11W Enabled; x = MBSSID Tx BSS; 3 = WPA3 BSS;
    d0:15:a6:c4:11:cd#
  • 11.  RE: SSID not boardcasting
    Posted Mar 23, 2023 05:41 PM
    your screenshots shows that the radios are disabled. Are you physically next to the APs if so is the AP's radio LED red in colour?
    what AP model is this and is it getting enough PoE?
    one thing to do is that to enable Intelligent Power Monitoring (IPM)
  • 12.  RE: SSID not boardcasting
    Posted Mar 24, 2023 12:01 AM
    No, the AP's LEDis orange color.
    AP-555 and now is
    I enabled the IPM, but the radio still disabled.
  • 13.  RE: SSID not boardcasting
    Posted Mar 24, 2023 12:20 AM
    AP-555 does not support 802.3 af power source. it is mentioned in the datasheet.
  • 14.  RE: SSID not boardcasting
    Posted Mar 24, 2023 12:36 AM
    so i must use 802.3bt as the power source input?
  • 15.  RE: SSID not boardcasting
    Posted Mar 24, 2023 12:40 AM
    that would be ideal but you can also use 802.3at poe sources with IPM, which you have now enabled.
    check the datasheet for details
