that would be ideal but you can also use 802.3at poe sources with IPM, which you have now enabled.
Original Message:
Sent: Mar 24, 2023 12:35 AM
Subject: SSID not boardcasting
so i must use 802.3bt as the power source input?
Original Message:
Sent: Mar 24, 2023 12:20 AM
AP-555 does not support 802.3 af power source. it is mentioned in the datasheet.
Original Message:
Sent: Mar 24, 2023 12:00 AM
your screenshots shows that the radios are disabled. Are you physically next to the APs if so is the AP's radio LED red in colour?
No, the AP's LEDis orange color.
what AP model is this and is it getting enough PoE?
AP-555 and now is
one thing to do is that to enable Intelligent Power Monitoring (IPM)
I enabled the IPM, but the radio still disabled.
Original Message:
Sent: Mar 23, 2023 05:40 PM
Original Message:
Sent: Mar 23, 2023 01:27 PM
What is the firmware of the APs and the region of the APs (e.g ROW, US?)?
firmware: 8.10.0.5_85552 & AP'sregion: HK
Have you also set the country code for the APs?
yes, HK
Did you also assign a radio profile to the APs?
No
What is the output of 'show ap bss-table' ?
d0:15:a6:c4:11:cd# show ap bss-table
Aruba AP BSS Table
bss ess port ip band/ht-mode/bandwidth ch/EIRP/max-EIRP type cur-cl ap name in-t(s) tot-t flags
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:0
Num Associations:0
Flags: a = Airslice policy; A = Airslice app monitoring; c = MBO Cellular Data Capable BSS; d = Deferred Delete Pending; D = VLAN Discovered; E = Enhanced-open BSS without transition mode; I = Imminent VAP Down; K = 802.11K Enabled; m = Agile Multiband (MBO) BSS; M = WPA3-SAE mixed mode BSS; o = Enhanced-open transition mode open BSS; O = Enhanced-open BSS with transition mode; r = 802.11r Enabled; t = Broadcast TWT Enabled; T = Individual TWT Enabled; W = 802.11W Enabled; x = MBSSID Tx BSS; 3 = WPA3 BSS;
d0:15:a6:c4:11:cd#
Original Message:
Sent: Mar 23, 2023 12:02 PM
Could be a few reasons for this......
Original Message:
Sent: Mar 23, 2023 11:59 AM
anyone can help?
Original Message:
Sent: Mar 22, 2023 02:18 PM
i changed to WPA2-Personal, but still fail.
Original Message:
Sent: Mar 22, 2023 01:53 PM
Have you tried it using WPA2-Personal? If that works then check to see if you have WPA3 Transition turned on with WPA3-Personal.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Mar 22, 2023 01:46 PM
Original Message:
Sent: Mar 22, 2023 01:35 PM
Can you send along similar screenshots like below:
Dustin Burns
Original Message:
Sent: Mar 22, 2023 12:49 PM
YES, THE Auto commit state IS ON
Original Message:
Sent: Mar 22, 2023 07:46 AM
Have you checked the config audit?
Dustin Burns
Original Message:
Sent: Mar 22, 2023 06:31 AM
Dear ALL,
I 'n newbie in aruba, i added the 2 x AP into aruba central, then i create the SSID, but i found the SSID:testing is not boardcasting and the SSID:SetmeUP is boardcasting.
Anyone can help?
