Wired
last person joined: 35 minutes ago
Stack ring of eight 6200M ; Bandwidth behavior question.
  • 1.  Stack ring of eight 6200M ; Bandwidth behavior question.
    Posted Nov 09, 2023 10:29 AM
    Assuming a stack ring of eight 6200M and the nodes are numbered clockwise from 1 to 8.
    All connection are 10Gbps between switches.
    If switch #5 want to send 20G of data to Switch#6.
    Does it will use the direct 10G connection ( 5-6) plus the other path counterclockwise ( 5-4-3-2-1-8-7-6) to achieve 20Gbps ?
    I am trying to find document explaining this.
    Alessio2023
  • 2.  RE: Stack ring of eight 6200M ; Bandwidth behavior question.
    Posted Nov 15, 2023 12:21 PM
    Same question - new to the CX 6200M, coming from the 2930M switches with the separate two port stacking module.
    Does anyone know specifically how the stacking bandwidth / throughput between two 2930M switches and two 6200M switches are different?
