Wired Intelligent Edge
Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
This thread has been viewed 77 times
  • 1.  Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 29 days ago
    We have 2 Aruba 6405 CX OS switches in VSX. Recently we precured vmWare with standard licenses. We know that LACP does support in this licenses. We configured static McLAG in our Aruba switches and "Routed Based On IP Hash" in vmWare. But after this configuration, vmWare host becomes unreachable. Getting ping response on some random systems. Some users are able to ping and some are not. Even ping reply from vmWare host is coming on primary VSX switch but not on secondary switch however ARP is available on both Cores. These 6405 VSX switches are L3 for users VLAN and Server VLAN.
    I checked vmWare documents and found document with sample configuration for Cisco, HP and Dell switches but no document available for Aruba CS OX switches.
    Below is switches configuration:
    Primary Switch
    CORE-SWH-PRI# sh running-config interface lag50
    interface lag 50 multi-chassis static
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed 51
        exit
    CORE-SWH-PRI# sh lag 50
    System-ID       : d4:e0:53:b1:07:00
    System-priority : 65534
    Aggregate lag50 is up
     Admin state is up
     Description :
     Type                        : multi-chassis
     Lacp Fallback               : Disabled
     MAC Address                 : 02:02:00:00:01:00
     Aggregated-interfaces       : 1/3/3 1/3/21
     Aggregation-key             : 50
     Aggregate mode              : static
     Hash                        : l3-src-dst
     LACP rate                   : n/a
     Speed                       : 20000 Mb/s
     Mode                        : trunk
    CORE-SWH-PRI# sh running-config interface 1/3/3
    interface 1/3/3
        description vmWare
        no shutdown
        lag 50
        exit
    CORE-SWH-PRI# sh running-config interface 1/3/21
    interface 1/3/21
        description vmWare
        no shutdown
        lag 50
        exit
    Secondary Switch
    CORE-SWH-SEC# sh running-config interface lag50
        no shutdown
        no routing
        vlan trunk native 1
        exit
    CORE-SWH-SEC# sh lag 50
    System-ID       : d4:e0:53:b1:87:00
     Admin state is up
     Description :
     Aggregated-interfaces       : 1/3/3 1/3/7
     Hash                        : l3-src-dst
     LACP rate                   : n/a
     Speed                       : 20000 Mb/s
     Mode                        : trunk
    CORE-SWH-SEC# sh running-config interface 1/3/3
    interface 1/3/3
        description vmWare
        no shutdown
        lag 50
        exit
    CORE-SWH-SEC# sh running-config interface 1/3/7
    interface 1/3/7
        description vmWare
        no shutdown
        lag 50
        exit
    Also attaching screenshots of vmWare setting.
    Kindly correct me if I have done some wrong config or share any reference document if you have.
  • 2.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    MVP GURU
    Posted 29 days ago
    Hi, have a look at this old thread about VSX LAG (static) with a VMware ESXi vSS (virtual Standard Switch)'s links aggregate. If I were you I will add the VLAN 1 to the allowed VLANs (vlan trunk allowed 1,51 instead of only vlan trunk allowed 51). If VSX configuration is already OK, it would also help to add the "l3-src-dst" option on the Active Gateway section of each SVI on the VSX Primary (the active gateway's l3-src-dst option configures the Virtual Gateway MAC address as the Source MAC for routed packets), see here as example.
  • 3.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    MVP GURU
    Posted 29 days ago
    Don't use LACP with vSS ! it is not needed !
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 4.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 29 days ago
    Hi, We are not configuring LACP. Doing static aggregation as vmWare vSS doesn't support LACP. Some users are able to ping the vmWare host and some are not. vmWare host has total 4 nics. 2 are connected on primary core switch and 2 are on secondary core switch. both core are connected with VSX. All users get ping reply when we disable 3 nic and leave 1 nic enable on switch.
  • 5.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    MVP GURU
    Posted 29 days ago
    * No need Link Aggregation on switch with VMware ESXi
  • 6.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 29 days ago
    What is the configuration on the vSwitch side regarding distribution of traffic to the various NICs (teaming and failover policy)? Are they all "active" or do you have an active/standby setup? What is the load balancing algo you selected? Do you see the MAC addresses of the VMs not reachable in the MC-LAG interface?
    Be aware that depending on the load balancing you configure you need or you dont need any special config on the physical switch. Please refer to VMware's documentation for further details.
    Thomas
  • 7.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 28 days ago
    All NICs are in Active mode. Load balancing algo is "Route based on IP hash". All 4 NICs are up and are in static bundle. When I ping vmWare host from Core switch primary, host is responding and when I ping vmWare host from Core switch secondary, host is not responding. However ARP is getting resolved on both switches on interface LAG50 with same MAC address.
  • 8.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 27 days ago
    For vsphere standard vswitch (i.e. no LACP), the best approach I would recommend is to not configure LAG at all and have each vmnic being connected to the switches as a standalone NIC, with just regular VLAN trunking. This should give best outcome.
  • 9.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 26 days ago
    Hi, We tested this setting also. Configured all 4 ports on both switches (2 ports on each switch) as standalone trunk ports with required vlans. Configured "route base on originating virtual port" algo on vmWare. Cons of this setting is that one VM will be bind with one physical nic only. There will be no load sharing for that particular VM on all physical nic.
    We want to share the VM load on all physical nic and that is possible in algo "Route based on IP hash". Whish requires static bundling at switch side.
  • 10.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 12 days ago
    Be careful regarding one specific configuration.
    Even if you configure your "vSwitch0" for "Route based on IP hash", by default the vmk0 interface/Management Network port group (used to manage the ESXi itself) has an explicit ovverride (see screenshot below).
    If you remove that (set to "inherit from vswitch"), you will be able to use "Route based on IP hash" also for reaching ESXi.
    What I usually do to avoid this is to keep separate interfaces for ESXi management (active/standby), and additional interfaces for workloads. And the vswitch for that interfaces will be configured with "Route based on IP hash".
  • 11.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    MVP GURU
    Posted 29 days ago
    Hi! could you paste the output of the CLI commands:
    • show vsx lacp aggregates lag50 (executed on both VSX members)
    • show lacp interfaces (no matter we are dealing with a static VSX LAG)
    Out of curiosity: shouldn't be better to have both the LAGs lag50 (the static VSX LAG lag50 as defined on the VSX Primary and the corresponding static VSX LAG lag50 defined on the VSX Secondary) to use the same "set of member interfaces" (I mean, say lag50: 1/3/3 + 1/3/21 or lag50: 1/3/3 + 1/3/7 on both VSX members instead of, as it is now, VSX Primary lag50: 1/3/3+1/3/21 and VSX Secondary lag50: 1/3/3+1/3/7)? it is not an essential requirement, just a good practice to ease the troubleshooting.
  • 12.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 28 days ago
    Hi, thanks for your response. kindly find the requested cmds output.
    Core-Switch(config)# show vsx lacp aggregates lag50
                        Local-peer                        Remote-peer
    Aggregate name   : lag50 (multi-chassis)             lag50 (multi-chassis)
    Interfaces       : 1/3/21 1/3/3                      1/3/3 1/3/7
    Peer interfaces  : 1/3/7 1/3/3                       1/3/21 1/3/3
    Heartbeat rate   : N/A                               N/A
    Hash             : l3-src-dst                        l3-src-dst
    Aggregate mode   : Off                               Off
    Core-Switch(config)# exit
    Core-Switch# show lacp interfaces | in lag50
    Actor details of all interfaces:
    1/3/3      lag50(mc)                                                    up
    1/3/21     lag50(mc)                                                    up
    Partner details of all interfaces:
    1/3/3      lag50(mc)
    1/3/21     lag50(mc)
  • 13.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 27 days ago
    One other thing to check on the VMware side is to make sure the port group is set to "Routed Based On IP Hash" as well. Can you post a screenshot of the VLAN 51 port group?
    Typically the port group is set to inherit from the vswitch but just double check, also if it is set to inherit, manually set it to "Routed Based On IP Hash" and see if that fixes the issue. I have run into this issue a few times!
  • 14.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    MVP GURU
    Posted 27 days ago
    To me it doesn't look like an issue at (VSXI) static LAG level...since both lag50 are up (although when set to static there are less informative output coming from the typical show lacp interfaces command). If vSS side (virtual Standard Switch) side all setting are OK matching those of the VSX LAGs the issue should be at an higher level (routing?).
  • 15.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 26 days ago
    Sorry, you have to uselize vSphere Distributed Switch for LACP
    Steinar
  • 16.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 26 days ago
    Hi, we are not using LACP. We configured static bundle and that supports in standard vSphere.
  • 17.  RE: Static LAG in VSX Aruba 6400 CX OS for vSphere Standard vSwitches
    Posted 26 days ago
    Try this:
    and folow Vincent advice. (no Lacp/Lag)
    Steinar
