Wired Intelligent Edge
Storm Control in CX switches
This thread has been viewed 23 times
  • 1.  Storm Control in CX switches
    Posted Jun 08, 2023 04:36 PM
    Hi community!
    I can't find any documentation for Storm Control in the CX switches. I'm now suspecting is not supported!?
    Regards!
  • 2.  RE: Storm Control in CX switches
    Posted Jun 08, 2023 08:54 PM
    rate-limit could be what you're looking for, it's in the CX QOS guide
    https://www.arubanetworks.com/techdocs/AOS-CX/10.10/PDF/qos_6200-6300-6400.pdf
    https://www.arubanetworks.com/techdocs/AOS-CX/10.10/PDF/qos_832x-10000.pdf
  • 3.  RE: Storm Control in CX switches
    Posted Jun 09, 2023 07:12 AM
    Strom-Control is included in the feature fault-monitor which can be found in the security guide.
  • 4.  RE: Storm Control in CX switches
    Posted Jun 09, 2023 05:27 PM
    Thank you Holger!
  • 5.  RE: Storm Control in CX switches
    Posted Sep 24, 2023 11:18 PM
    The fault-monitor actions you can take are to log the event or block the port which could be rather extreem. It seems if you want visability of possible fault conditions but not block ports you'd have to instead apply a per port rate-limit <boardcast|multicast|unkown|icmp> and use fault-monitor just to inform you something is going on.
    It would be nice if fault monitor allowed you to rate limit rather than just block.
