SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
System IP address Loopback or VLAN4087
  • 1.  System IP address Loopback or VLAN4087
    Posted Mar 27, 2024 11:09 AM
    I am still a little confused about the concept of the system IP address
    In it said to be important for Gateways and microbranches
    One thing I don't understand is that some documentation states that VLAN 4087 is reserved for this purpose while other airhead videos use a different VLAN for this, and you can also use a Loopback interface.
    Being familiar with Loopback and its purpose for many other vendors, why at all use VLAN 4087 or any other VLAN for that matter, and just use a Loopback interface?
    Also would defining both a Loopback and a system IP be redundant?
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: System IP address Loopback or VLAN4087
    Posted Mar 29, 2024 02:12 AM
    you can use any VLAN ID as a system IP.
    You can also use loopback
    check the Aruba SD-Branch Fundamentals Guide
  • 3.  RE: System IP address Loopback or VLAN4087
    Posted Mar 31, 2024 07:11 AM
    Hi Ariy-,
    thank you for responding, however it feels a little like an echo of my question. I understand I can use both. I guess I can draw the conclusion that the Aruba guides could benefit from simplification.  My conclusion is you can use any IP address and if you are used to using loopback addresses stay consistent with that.
    is it true though is VLAN 4087 reserved on gateways?
    https://www.arubanetworks.com/techdocs/central/2.5.2/content/gateways/cfg/bgw-dev-system-page.htm
  • 4.  RE: System IP address Loopback or VLAN4087
    Posted Apr 01, 2024 06:20 PM
    even the current Central doco states that.
    It is reserved for the guided BGW workflow to make it easier I suppose. But again you can use any interface.
    also for example If you use a VLAN pool for system-ip, it is basically dynamically creating loopback interface.
  • 5.  RE: System IP address Loopback or VLAN4087
    Posted 19 days ago
    but you can't use a vlan interface if its deployed via DHCP such as in azure
