even the current Central doco states that.
It is reserved for the guided BGW workflow to make it easier I suppose. But again you can use any interface.
also for example If you use a VLAN pool for system-ip, it is basically dynamically creating loopback interface.
Original Message:
Sent: Mar 31, 2024 07:11 AM
Subject: System IP address Loopback or VLAN4087
Hi Ariy-,
thank you for responding, however it feels a little like an echo of my question. I understand I can use both. I guess I can draw the conclusion that the Aruba guides could benefit from simplification. My conclusion is you can use any IP address and if you are used to using loopback addresses stay consistent with that.
is it true though is VLAN 4087 reserved on gateways?
https://www.arubanetworks.com/techdocs/central/2.5.2/content/gateways/cfg/bgw-dev-system-page.htm
Martijn van Overbeek
Architect, Netcraftsmen a BlueAlly Company
Original Message:
Sent: Mar 29, 2024 02:12 AM
you can use any VLAN ID as a system IP.
You can also use loopback
check the Aruba SD-Branch Fundamentals Guide
Original Message:
Sent: Mar 27, 2024 11:08 AM
I am still a little confused about the concept of the system IP address
In it said to be important for Gateways and microbranches
One thing I don't understand is that some documentation states that VLAN 4087 is reserved for this purpose while other airhead videos use a different VLAN for this, and you can also use a Loopback interface.
Being familiar with Loopback and its purpose for many other vendors, why at all use VLAN 4087 or any other VLAN for that matter, and just use a Loopback interface?
Also would defining both a Loopback and a system IP be redundant?
