System running with low disk space
This thread has been viewed 19 times
  • 1.  System running with low disk space
    MVP EXPERT
    Posted Nov 15, 2023 03:20 AM
    CPPM 6.11.5
     4 node cluster,
    two nodes are generatibng evenet messages saying System is running loq on disk space. Agressive cleanup of /var/log$ will be initiated when the available disk space falls below 20% Current available disk space 25%
    These cluster nodes happen to host my primary and secondary insight  databases.
    System monitor shows 61/820 GB used , no swap space used
    Had an issue with these boxes before wher they ran out of /var/log space and needed a reboot to get them  working again. Problem is that 1 of them is the master publisher
    Is this a 6.11 thing?
    A
  • 2.  RE: System running with low disk space
    MVP
    Posted Nov 15, 2023 05:00 AM
    This is a well known bug on 6.11.0 , we solved this with upgrade to 6.11.5 after support recommendation.
    Shpat | ACEP | ACMP | ACCP | ACDP |
    -Just an Aruba enthusiast and contributor by cases-
  • 3.  RE: System running with low disk space
    MVP EXPERT
    Posted Nov 15, 2023 06:39 AM
    Sadly the cluster is running 6.11.5 :-(
    Sent from my iPhone
  • 4.  RE: System running with low disk space
    Posted 27 days ago
    Hi Alexs-nd,
    Did you manage to solve this issue? We are facing the same since the upgrade to ClearPass  6.11.8.
    Thanks in advance!
    Lex
  • 5.  RE: System running with low disk space
    Posted 26 days ago
    Hi
    We had an physical C3010 server with an issue with the iLO card generating a lot of log that wasn't removed during normal clean up nor aggresive clean up jobs. In that case we got the motherboard of the server replaced as the iLO interface was in a stuck state and we could not log in to it.
    But I have also run into disk issues on various versions of ClearPass 6.11.x.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 6.  RE: System running with low disk space
    Posted 26 days ago
    As of ClearPass 6.11 the logs are stored on a separate partition and the free space calculation is done based on that partition size, not the entirety of the disk available to the system.  This was done to prevent the logs from impacting the overall system from operating.
    If you are worried about the message, then open a case with TAC so that a determination can be made as to what is causing the potential excessive logging to happen.
    Carson Hulcher, ACEX#110
