Cloud Managed Networks
Troubleshooting RADIUS response, authenticator side (Switch)
This thread has been viewed 37 times
  • 1.  Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 02:39 AM
    Hi All,
    We have Aruba central managed switches and we have on-prem Clearpass cluster. We came across the problem where the RADIUS reply from Clearpass contained an Aruba-User-Role of: "access-point" and on the switch there was: port-access role access-points. In Clearpass all you can see is an accept in the access tracker and everything looks fine from the side of Clearpass. However on the side of the switch the AP is of course not going to get connected because there is no correct port-access role configured.
    Now for the question: Without comparing the running config on the switch with the Enforcement Profiles on Clearpass, how would you troubleshoot this on the switch to be able to see that the switch cannot do anything with the received RADIUS response since there is no correct port-access role configured on the switch?
    EDIT:
    With the command: "show port-access clients" you could see that the AP only did mac-auth and not dot1x:
    c 1/1/28   f0:61:c0:ca:91:0e mac-auth       Success              io-prov-ap
    But that doesn't help in troubleshooting where this has gone wrong. In the logging of the switch there was also no indication that the role doesn't exist on the switch so the switch is just not going to do anything with that RADIUS response.
  • 2.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 03:19 AM
    The command:
    show port-access clients interface 0/0/1 detail
    will show more details. Things that I have seen regularly are that the role VLAN is not configured/active on the switch, or that conflicting information is received in the RADIUS response like a user-role and separate VLAN.
    What type of switch do you have? AOS-CX or ArubaOS-Switch?
  • 3.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 03:22 AM
    if you are getting "Critical " as use role, then that means RADIUS server is not reachable.
  • 4.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 04:13 AM
    My bad. I have updated the topic. The switch only could do mac-auth, but dot1x wasn't working because the radius response contained a role that the switch didn't have configured.
    So the question still remains:
    How would you troubleshoot this problem, without comparing the running config on the switch with the configured config in Clearpass. (That's how I found and solved the problem initially) Isn't there a command to show that the switch doesn't have the correct role configured for the RADIUS response from Clearpass?
  • 5.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 04:07 AM
    Currently we have already solved the problem by correcting the config on the switch to: "port-access role access-point". We didn't use the detail when troubleshooting this problem initially. I did type it in now on a switch to see what the detail part would show. I don't have a lab setup where I would be able to make a config mistake and see what the "show port-access clients interface 0/0/1 detail" would extra show to help troubleshooting this configuration mistake. Would you be able to test that out in a lab setup?
    We have AOS-CX switches with a template configuration in Aruba Central.
  • 6.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 03, 2024 04:38 AM
    Apparently I do have a test setup :). First I show that dot1x is working correctly with the correct role: "access-point":
    NLUT--SD05401# show port-access clients
    Port Access Clients
    Status Codes: d device-mode, c client-mode, m multi-domain
      Port     MAC-Address       Onboarding     Status               Role                                Device Type
                                 Method
    d 1/1/28   f0:61:c0:ca:91:0e dot1x          Success              access-point
    I then put the switch in aruba-central support-mode, broke the config so that the correct role isn't anymore on the switch. And then removed POE from the port and enabled POE on the port again, so that the AP would go through the whole authentication process again:
    NLUT--SD05401# aruba-central support-mode
    NLUT--SD05401(config)# port-access role access-points
    NLUT--SD05401(config-pa-role)#  auth-mode device-mode
    NLUT--SD05401(config-pa-role)#     poe-priority high
    NLUT--SD05401(config-pa-role)#     trust-mode dscp
    NLUT--SD05401(config-pa-role)#     stp-admin-edge-port
    NLUT--SD05401(config-pa-role)#     vlan access 99
    NLUT--SD05401(config-pa-role)# exit
    NLUT--SD05401(config)# no port-access role access-point
    NLUT--SD05401(config)# do show run | b "access-point"
        poe-priority high
        trust-mode dscp
        stp-admin-edge-port
        vlan access 99
    We then see a 802.1x fail on the switch with the show port-access clients:
    Port Access Clients
                                 Method
    c 1/1/28   f0:61:c0:ca:91:0e dot1x          Fail
    If we go into detail we see the following information, but in my humble opinion this still doesn't help you to troubleshoot that the RADIUS response contains a role that the switch doesn't have and so won't do anything with that RADIUS response:
    NLUT--SD05401# show port-access clients in 1/1/28 detail
    Port Access Client Status Details:
    Client f0:61:c0:ca:91:0e, NLUT--SD05F061C0CA910E
      Session Details
        Port         : 1/1/28
        Session Time : 91336s
        IPv4 Address :
        IPv6 Address :
        Device Type  :
      VLAN Details
        VLAN Group Name :
        VLANs Assigned  :
          Access          :
          Native Untagged :
          Allowed Trunk   :
      Authentication Details
        Status          : dot1x Authenticated
        Auth Precedence : dot1x - Authenticated, mac-auth - Not attempted
        Auth History    : dot1x - Authenticated, 91312s ago
                          mac-auth - Authenticated, 91336s ago
      Authorization Details
        Role   :
        Status : Invalid
    The logging on the switch also doesn't show anything useful, maybe there is a different logging I need to check to get to the root cause of this issue, but with the command provided below I cannot determine the root cause:
    NLUT--SD05401# show logg -r | i 1/1/28
    2024-05-03T04:21:21.158944-04:00 NLUT--SD05401 lldpd[3479]: Event|106|LOG_INFO|CDTR|1|LLDP neighbor f0:61:c0:ca:91:0e deleted on 1/1/28
    2024-05-03T04:19:35.748669-04:00 NLUT--SD05401 ops-switchd[661]: Event|2110|LOG_INFO|CDTR|1|Deleted Mac based VLAN entry for f0:61:c0:ca:91:0e with VLAN 4001 on port 1/1/28
    2024-05-03T04:19:35.745583-04:00 NLUT--SD05401 lldpd[3479]: Event|113|LOG_INFO|CDTR|1|PVID mismatch on 1/1/28 pvid = 1, Neighbor f0:61:c0:ca:91:0e port_id = f0:61:c0:ca:91:0e pvid = 0
    2024-05-03T04:19:35.728793-04:00 NLUT--SD05401 port-accessd[4159]: Event|10502|LOG_INFO|CDTR|1|Port 1/1/28 is blocked by port-access
    2024-05-03T04:19:16.705754-04:00 NLUT--SD05401 lldpd[3479]: Event|104|LOG_INFO|CDTR|1|LLDP neighbor f0:61:c0:ca:91:0e added on 1/1/28
    2024-05-03T04:19:12.768889-04:00 NLUT--SD05401 port-accessd[4159]: Event|10503|LOG_INFO|CDTR|1|Port 1/1/28 is unblocked by port-access
    2024-05-03T04:19:12.746117-04:00 NLUT--SD05401 ops-switchd[661]: Event|9707|LOG_INFO|CDTR|1|Created Mac based VLAN entry. VLAN 4001 is mapped to client f0:61:c0:ca:91:0e on port 1/1/28
    2024-05-03T04:19:12.726194-04:00 NLUT--SD05401 ops-switchd[661]: Event|2108|LOG_INFO|CDTR|1|Created Mac based VLAN entry. VLAN 4001 is mapped to client f0:61:c0:ca:91:0e on port 1/1/28
    2024-05-03T04:18:39.626479-04:00 NLUT--SD05401 port-accessd[4159]: Event|10502|LOG_INFO|CDTR|1|Port 1/1/28 is blocked by port-access
    2024-05-03T04:18:39.599223-04:00 NLUT--SD05401 intfd[684]: Event|403|LOG_INFO|UKWN|1|Link status for interface 1/1/28 is up
    2024-05-03T04:18:14.163772-04:00 NLUT--SD05401 poe-hald[3488]: Event|7902|LOG_INFO|CDTR|1|Powered device power delivery on interface 1/1/28
    2024-05-03T04:18:14.161277-04:00 NLUT--SD05401 poe-protod[3498]: Event|7901|LOG_INFO|CDTR|1|Detected powered device on interface 1/1/28. Type:2, Class:4
    2024-05-03T04:18:08.411300-04:00 NLUT--SD05401 port-accessd[4159]: Event|10503|LOG_INFO|CDTR|1|Port 1/1/28 is unblocked by port-access
    2024-05-03T04:18:08.386002-04:00 NLUT--SD05401 intfd[684]: Event|404|LOG_INFO|UKWN|1|Link status for interface 1/1/28 is down
    2024-05-03T04:18:07.378573-04:00 NLUT--SD05401 poe-protod[3498]: Event|7906|LOG_INFO|CDTR|1|PoE disabled on interface 1/1/28
    I end with a print-screen of what you'd be able to see in the access-tracker in Clearpass, which again isn't going to help you troubleshoot this issue:
    We're back to where we started and the original question still remains:
    How do you troubleshoot this problem, where the RADIUS response from Clearpass contains a role which the switch doesn't know and therefore won't authenticate the client with the correct role?
  • 7.  RE: Troubleshooting RADIUS response, authenticator side (Switch)
    Posted May 04, 2024 01:58 AM
    In most cases just compare values in Clearpass access tracker output tab with the switch configuration.
    It would be really helpful to have at least log entry saying that receiving role does not exist on switch.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
