In my experience, configuring the same SSID in the same Ap-group registers an error. If this is not prevented and you are broadcasting the same SSID twice in the same Ap-group, how would you know or control which one you are connecting to?
HPE Design and Deploy Guides:
https://community.arubanetworks.com/support/migrated-knowledge-base?attachments=&communitykey=dcc83c62-1a3a-4dd8-94dc-92968ea6fff1&pageindex=0&pagesize=12&search=&sort=most_recent&viewtype=card------------------------------
Original Message:
Sent: Mar 14, 2023 08:23 AM
Subject: tunnel vap and bridge vap same ap group question
Hi, no problem at all having 2 ssids with diferent types in the same group. It's common.
Regards
Original Message:
Sent: Mar 13, 2023 08:26 AM
hi dear
If there are both tunnel ssid and bridge ssid under one AP group, will there be any problems in use?
Because this kind of situation has not been encountered in the project, we generally separate the two modes into different ap groups.
leo ma
