"unsafe legacy renegotiation disabled" errors from OpenSSL 3
  • 1.  "unsafe legacy renegotiation disabled" errors from OpenSSL 3
    Posted Feb 28, 2024 04:58 AM
    It seems that newer versions of OpenSSL (as shipped in RHEL 9) are refusing to talk to my Instant 8.6.0.23 devices:
    $ curl https://192.0.2.1:4343/
    curl: (35) OpenSSL/3.1.1: error:0A000152:SSL routines::unsafe legacy renegotiation disabled
    In case anyone else is scratching their head over this, the workaround is to add the UnsafeLegacyServerConnect option, documented in SSL_CONF_cmd(3ossl), to your openssl.cnf file. Finding the right point in that file is quite difficult, but for RHEL 9, it needs to be added here:
    [ crypto_policy ]
    # BEGIN LOCAL MODIFICATIONS
    # <https://bugzilla.redhat.com/show_bug.cgi?id=2072070>
    # <https://gitlab.com/redhat-crypto/fedora-crypto-policies/-/issues/42>
    Options = UnsafeLegacyServerConnect
    # END LOCAL MODIFICATIONS
    .include = /etc/crypto-policies/back-ends/opensslcnf.config
    While investigating this I used sslyze to analyze the Instant's TLS server configuration and it gave me a couple of findings (I've elided the uninteresting parts):
    $ podman run --rm -it docker.io/nablac0d3/sslyze:latest 192.0.2.1:4343
     SCAN RESULTS FOR 192.168.88.4:4343 - 192.168.88.4
     * Session Renegotiation:
           Client Renegotiation DoS Attack:   OK - Not vulnerable
           Secure Renegotiation:              VULNERABLE - Secure renegotiation not supported
    COMPLIANCE AGAINST MOZILLA TLS CONFIGURATION
        Checking results against Mozilla's "intermediate" configuration. See https://ssl-config.mozilla.org/ for more details.
        192.168.89.4:4343: FAILED - Not compliant.
            * ciphers: Cipher suites {'TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256', 'TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384'} are supported, but should be rejected.
            * tls_vulnerability_renegotiation: Server is vulnerable to the insecure renegotiation attack.
    Aside from sslyze picking up on the same insecure renegotiation vulnerability that causes OpenSSL to reject connections to the controller, it also notes that a couple of older CBC-mode ciphersuites are still in use. Hopefully the TLS configuration can be modernized in future releases (if not already done in 8.11 or 10).
  • 2.  RE: "unsafe legacy renegotiation disabled" errors from OpenSSL 3
    Posted Feb 28, 2024 05:39 AM
    BTW, a decent explanation of the implications of the UnsafeLegacyServerConnect option (which corresponds to SSL_OP_ALLOW_UNSAFE_LEGACY_RENEGOTIATION in code) is found in SSL_CTX_set_options(3ossl):
    SECURE RENEGOTIATION
           OpenSSL always attempts to use secure renegotiation as described in RFC5746. This counters the prefix attack
           described in CVE-2009-3555 and elsewhere.
           This attack has far reaching consequences which application writers should be aware of. In  the  description
           below  an  implementation supporting secure renegotiation is referred to as patched. A server not supporting
           secure renegotiation is referred to as unpatched.
           The following sections describe the operations permitted by OpenSSL's secure renegotiation implementation.
     Patched OpenSSL client and unpatched server
           If the option SSL_OP_LEGACY_SERVER_CONNECT or SSL_OP_ALLOW_UNSAFE_LEGACY_RENEGOTIATION is set  then  initial
           connections  and  renegotiation  between  patched OpenSSL clients and unpatched servers succeeds. If neither
           option is set then initial connections to unpatched servers will fail.
           Setting the option SSL_OP_LEGACY_SERVER_CONNECT has security  implications;  clients  that  are  willing  to
           connect  to  servers  that  do  not  implement  RFC 5746 secure renegotiation are subject to attacks such as
           CVE-2009-3555.
           OpenSSL client applications wishing to ensure they can  connect  to  unpatched  servers  should  always  set
           OpenSSL  client  applications  that want to ensure they can not connect to unpatched servers (and thus avoid
           any security issues) should  always  clear  SSL_OP_LEGACY_SERVER_CONNECT  using  SSL_CTX_clear_options()  or
           SSL_clear_options().
           The difference between the SSL_OP_LEGACY_SERVER_CONNECT and SSL_OP_ALLOW_UNSAFE_LEGACY_RENEGOTIATION options
           is  that  SSL_OP_LEGACY_SERVER_CONNECT  enables initial connections and secure renegotiation between OpenSSL
           clients  and  unpatched  servers  only,  while   SSL_OP_ALLOW_UNSAFE_LEGACY_RENEGOTIATION   allows   initial
           connections and renegotiation between OpenSSL and unpatched clients or servers.
  • 3.  RE: "unsafe legacy renegotiation disabled" errors from OpenSSL 3
    Posted Feb 28, 2024 09:27 AM
    Aruba Instant 8.6.x is end of support. If your APs support, you may attempt to upgrade to 8.10 or 8.11.
    When testing with 8.11.2.0 in my lab, I don't see the tls_vulnerability_negotiation, so that seems fixed.
