Primary (K-12) Education
last person joined: 20 days ago
Got networking questions for schools or want to know more about E-rate? Submit them here!
Upgrade from 6x to 8x
  • 1.  Upgrade from 6x to 8x
    Posted Mar 07, 2022 04:41 PM
    We just did the upgrade from 6x to 8x.  In order to get and  stay under the 10,000 AP limit we had to leave 2000+ AP 105s on the the 6x system in the default group.
    If I disable the ADP on the 6x, will the APs in the default group stay on the 6x if rebooted?
    #show adp config
    ADP Configuration
    key value
    discovery enable
    igmp-join enable
    igmp-vlan 0
    Brian Warren
  • 2.  RE: Upgrade from 6x to 8x
    MVP EXPERT
    Posted Mar 10, 2022 06:53 AM
    Depends how the APs discover their master (static/DHCP/ADP/DNS) . The above configuration will disable broadcast/multicast responses from the Controller. For example, if the APs are using the same DNS record (aruba-master) and they all reboot then they will locate the controller IP specified in the aruba-master DNS record.
    Craig Syme
