Hi, you are correct that this hasn't been addressed in more recent versions.
The following link backs this up which is the view from the other side (CX docs):
It does seem to falsely claim "Partial configuration " in that doc though.
Original Message:
Sent: 4/9/2024 4:12:00 AM
Subject: RE: Upgrade of Aruba CX Switch firmware in AirWave
Thanks for the information
We can monitor, not any configiration in CX models as per the document
https://www.arubanetworks.com/techdocs/AirWave/8302/AirWave_8.3.0.2_Supported_Devices_Matrix.pdf
Original Message:
Sent: Apr 04, 2024 02:36 AM
Subject: Upgrade of Aruba CX Switch firmware in AirWave
Hi, the link below suggests a greater support for CX than just monitoring. Check you are on the latest version and search for the matrix that matches. The fact they mention specific models suggests it isn't support for the whole OS but rather specific models.
https://www.arubanetworks.com/techdocs/AirWave/82150/AirWave_8.2.15.0_Supported_Devices_Matrix.pdf
Original Message:
Sent: Apr 03, 2024 07:51 AM
Hi
If I am correct we can only the monitor the Aruba CX Switches in the AMP, not any configuration
Can we upgrade the FW of the CX Switches with the help of the AMP?
In addition, I am trying to upload the SWI image to the AirWave, and getting the error message "Invalid Aruba Device image"
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c5302580379b4d2299befab168e45432.png)
Thanks in Advance
