Wired
upgrade switch 3810 firmware
  • 1.  upgrade switch 3810 firmware
    Posted Mar 27, 2024 08:01 PM
    copy usb flash filename.swi to secondary,  it asking over write "Y"  after it completes sh flash still the file.  can someone advise?
  • 2.  RE: upgrade switch 3810 firmware
    Posted Apr 02, 2024 04:58 AM
    That is hard to tell without seeing the command output. Your firmware file may be corrupt, or the USB cannot be properly read; or it can be something different. Understanding the timing, like if the prompt returns immediately or after longer time may indicate if the file is actually transferred. Logs (show log -r) should provide more information.
    Please reach out to Aruba TAC if you need urgent help.
