That question about updating the certificate is unrelated to this topic. Please open your own topic/discussion, and add version, AP-type, management method, type of cert, etc.
Original Message:
Sent: Aug 30, 2022 02:20 AM
Subject: user interface https://instant.arubanetworks.com:4343/#home is not working
Hi ,
I need some help in updating the certificate of captive portal i have imported certificate in the configuration-- system-- certificate here i ahve imported the certificate but I don't know where to call this certificate in the captive portal so that the certificate should. Be updated pleas suggest thanks in advance
Original Message:
Sent: Aug 29, 2022 06:40 PM
once IAP cluster is managed by Aruba Central then you need to configure it from Aruba Central.
so go to your Aruba Central and make your changes from there.
Original Message:
Sent: Aug 29, 2022 08:28 AM
Hi, I'm not able to change / delete networks, neighter to use maintanance (nothing is available). System was setup with Aruba Central as management. Thx.
