Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Using an AP-225 as a home stand alone Access point
This thread has been viewed 19 times
  • 1.  Using an AP-225 as a home stand alone Access point
    Posted 30 days ago
    I have acquired an AP-225 and want to set it up on my home network to act as another Wi-Fi Access point, but it doesn't seem to to broadcast an SSID so I cant connect to it to set it up. I have tried a factory reset.
    Is this possible.
    Many thanks
  • 2.  RE: Using an AP-225 as a home stand alone Access point
    Posted 30 days ago
    For standalone operations you would need an IAP-225 model. The AP-225 requires a controller to operate.
  • 3.  RE: Using an AP-225 as a home stand alone Access point
    Posted 30 days ago
    Hi Herman
    Damn, that is what I was starting to suspect, thanks for confirming, will need to return it, shame, it looked like it would have been an ideal for my use, I know they are discontinued, but great quality and functionality compared with consumer Aps
    Thanks very much for your swift response.
    BR
    Andy
  • 4.  RE: Using an AP-225 as a home stand alone Access point
    Posted 19 days ago
    Hi Herman
    I have acquired what has been described as an IAP-325 (see image of label on rear), however when I power this up, I can not detect a broadcast SSID of the format SetMeUp
    This is what I should expect isn't it?
    Any Ideas?
    Many thanks
    Andy
  • 5.  RE: Using an AP-225 as a home stand alone Access point
    Posted 15 days ago
    If you already tried to factory reset it with a paper clip (google to get the right process), you may need to console into it to see what's going on - it could contain a corrupted firmware or worse yet, it is a faulty unit.
  • 6.  RE: Using an AP-225 as a home stand alone Access point
    Posted 14 days ago
    Seems like you found the issue already.
  • 7.  RE: Using an AP-225 as a home stand alone Access point
    Posted 14 days ago
    Hi Herman
    Yes thanks, very strange, I now will have to buy a USB-RS232 cable to try and connect to the console of the AP-225 and see if I can reflash it with IAP firmware
    Many thanks
    Andy
