Using Instant IAP-325 as Stand Alone home AP
  • 1.  Using Instant IAP-325 as Stand Alone home AP
    Posted Apr 30, 2024 09:00 AM
    I have acquired what has been described as an IAP-325 (see image of label on rear), however when I power this up, I can not detect a broadcast SSID of the format SetMeUp:xx.xx.xx
    The last section of label below the last barcode says (IAP-325 US), so looks like it is an Instant IAP-325.
    This is what I should expect isn't it?
    I was wondering if the previous owners may have re-flashed it a a standard AP-325 without web access and setup and only via a network controller, which I don't have)
    Any Ideas and suggestions would be most welcome?
    Many thanks
    Andy
  • 2.  RE: Using Instant IAP-325 as Stand Alone home AP
    Posted Apr 30, 2024 01:16 PM
    In a factory default state and not joined to Central or a local IAP cluster on the same network segment, you should see the SetMeUp SSID.
    Try consoling in (9600/8/N/1) and reboot the AP. The output should indicate the relevant information, but you may need to factory default the AP. Process is in the installation guide.
  • 3.  RE: Using Instant IAP-325 as Stand Alone home AP
    Posted May 01, 2024 09:28 AM
    Hi
    I have discovered the problem. The AP will not broadcast and SSID (SetMeUp or any) unless there is an ethernet cable plugged into port 0
    Not sure why that should be a requirement, as I wanted to configure the AP before attaching to the network.
    Thanks for your help
    BR
    Andy
  • 4.  RE: Using Instant IAP-325 as Stand Alone home AP
    Posted 30 days ago
    Glad you figured it out. What you observed is the default behavior. There are options to allow the AP to broadcast without an active uplink if required, but out of the box we expect the AP is plugged into the network for initial setup.
