Hi Tiffany,
Thank you for the answer, it is much appreciated. Yes, I'm definitely using v2, specifically 2.5.1. From what I can see, there is no mention of EVPN in the package, but excited to here that it might be on the agenda at some point. I'm not using Ansible but it is something that I should look into as I know little about it. Fun fact, the first time I ever used Ansible was at TSS in Paris at a lab that you were leading. I said to you then that I should look into Ansible and now I'm repeating myself, probably 7 - 9 years later!
If anyone else is looking to create EVPN configuration such as this
evnpn
vlan 998
rd auto
route-target export auto
route-target import auto
I have hacked/cut and pasted together an EvpnVlan class which inherits from pyaoscx's PyaoscxModule. To use the class, do this:
# I stuck the EvpnVlan class in a file called file called evpn.py in a folder
# named aruba_cxos_tools in my srcs root.
# You can put it wherever you like
from aruba_cxos_tools.evpn import EvpnVlan
def create_evpn_vni(vlan_id: int):
version = '10.09'
switch_ip = '1.1.1.1'
session = Session(switch_ip, version)
session.open(username='hello', password='hellohello')
vlan = Vlan(session, vlan_id)
vlan.get()
# you must pass the VLAN's URI to the EvpnVlan object, VLAN object
# or ID will not work.
evpn_vlan = EvpnVlan(session, vlan.get_uri())
evpn_vlan.create()
It does the bare minimum, but It will set import, export and RD to auto. Look at the below code if you want to change that. If I get considerably more useful and robust, I'll push to my github and paste the repo here, but if I'm honest, that's a long shot.
from pyaoscx.pyaoscx_module import PyaoscxModule
class EvpnVlan(PyaoscxModule):
base_uri = "system/evpn/evpn_vlans"
resource_uri_name = "vlans"
indices = ["id"]
def __init__(
self, session, vlan_id, uri=None, **kwargs
self.session = session
self._uri = None
self.evpn_vlans = {}
self.export_route_targets = ["auto"]
self.import_route_targets = ["auto"]
self.rd = "auto"
self.redistribute = {"host-route": True}
self.vlan = vlan_id
self.arp_suppression_enabled = None
self.dyn_vxlan_tunnel_bridging_mode = "no-bridging"
self.nd_suppression_enabled = True
self.redistribute = {}
# List used to determine attributes related to the VLAN configuration
self.config_attrs = []
self.materialized = False
# Attribute dictionary used to manage the original data
# obtained from the GET
self._original_attributes = {}
# utils.set_creation_attrs(self, **kwargs)
# Use to manage MACs
self.macs = []
# Use to manage Static MACs
self.static_macs = []
# Attribute used to know if object was changed recently
self.__modified = False
def create(self):
payload = {
"vlan": self.vlan,
"export_route_targets": self.export_route_targets,
"import_route_targets": self.import_route_targets,
"redistribute": self.redistribute,
"rd": self.rd,
self._post_data(payload)
def _post_data(self, data):
Perform a POST request to the switch.
:param data: data to send.
self._send_data(self.base_uri, data, "POST", "Adding")
# Get the data from the created object
self.get()
return True
@PyaoscxModule.connected
def get(self, depth=None, selector=None):
pass
@classmethod
def get_all(cls, session):
pass
def apply(self):
pass
def update(self):
pass
def delete(self):
pass
@classmethod
def from_response(cls, session, response_data):
pass
@classmethod
def from_uri(cls, session, uri):
pass
Cheers,
C
Original Message:
Sent: Mar 13, 2024 03:34 PM
Subject: v10.13 pycxaos, EVPN and package completeness
Hi @flatline! Thank you for your interest in our pyaoscx package! I can assure you this is something we're actively developing and improving! Internally we're continuously working on bug improvements and feature requests provided by users. I'm glad you were able to find a solution, is this using version 2.0.0+ of the python package? It seems so but I just wanted to verify. In regards to Ansible support for VNIs/VXLAN we have planned development for these features to be included but no estimation of delivery as of today as we're tackling other requests.
Ti Chiapuzio-Wong (they/them)
HPE Aruba Networking
Original Message:
Sent: Mar 13, 2024 11:43 AM
Thanks for that, that's put me on the right path. I've gotten it up and running. Looks like I hadn't actually done the EVI side of things after all, I'll need to look into that. But for the time being, this code will create a VLAN and an existing interface vxlan 1's VNI with the same ID as the VLAN if anyone is interested.
from typing import Dictfrom pyaoscx.session import Sessionfrom pyaoscx.interface import Interfacefrom pyaoscx.vni import Vnifrom pyaoscx.vlan import Vlanversion = '10.09'switch_ip = '1.1.1.1'evi = { "export_route_targets": [ "both" ], "import_route_targets": [ "both" ], "rd": "auto", "redistribute": { "host-route": True }, "vlan": 998}def main(): # TODO: catch exceptions and logout of session # TODO: add logging session = Session(switch_ip, version) session.open(username='jellybean', password='yum-yumyumyum') vlan_id = 998 vlan_name = "bob" vlans = Vlan.get_all(session) print(vlans.keys()) # confirm vlan exists, else create it if check_if_vlan_exists(vlans, 998): vlan = vlans[vlan_id] else: vlan = Vlan(session, vlan_id, name=vlan_name) vlan.create() # check that vlan name matches our desired name # TODO: api VLANS from Vlan.get() have a name attribute # TODO: but a a None value even though switch VLANs have a name # if vlan.name != vlan_name: # vlan.name = vlan_name # vlan.apply() # get interface vxlan 1 # TODO: check if interface exists, else create it interface = Interface(session, 'vxlan1') interface.get() # create vni # TODO: check if vni exists, else create it vni = { "vlan": vlan, "type": "vxlan_vni", } vni_id = vlan_id vni_string_id = f"vxlan_vni,{str(vni_id)}" all_vnis = Vni.get_all(session, interface) if check_if_vni_exists(all_vnis, vni_string_id): vni = all_vnis[vni_string_id] else: vni = Vni(session, 998, interface, **vni) vni.create() if check_if_vni_exists(vni.get_all(session, interface), vni_string_id): print("VNI exists") else: print("VNI does not exist") session.close()def check_if_vlan_exists(vlans: Dict, vlan_id: int): return key_attr_check(vlans, vlan_id)def check_if_vni_exists(vnis: Dict, vni_id: str): return key_attr_check(vnis, vni_id)def key_attr_check(obj: Dict, key) -> bool: attr = obj.get(key, None) if attr is not None: return True return Falseif __name__ == "__main__": main()
And here you can see the expected output from the switch
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/2e43e0e96d094422891e6e4daaeddcd2.png)
Original Message:
Sent: Mar 13, 2024 09:22 AM
Hi Conor,
You can look this playbook from this repo https://github.com/aruba/aoscx-ansible-dcn-workflows/blob/master/tasks/aoscx/vxlan.yml
it is using directly API call for add vxlan interface and vni (but it is using old v1 API and no longer supported, there is for example not longer system/port API call it is directly on system/interfaces)
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Mar 12, 2024 03:45 PM
Thank you, alagoutte.
Do you know which endpoint one would use to create an interface vxlan 1 and its VNI configurations. Looking at the POST /system/interfaces docs, one can send an options attribute with a
"tunnel_source_intf"
which looks promising, but I can't find what to send to create the VNI configuration under the vxlan interface configuration. The goal is to produce the following configuration from one or more calls to the switch's API.
interface vxlan 1
source ip 10.47.27.208
no shutdown
vni 5
vlan 5
Would you or anyone else reading this know which endpoint to use?
Cheers,
C
Original Message:
Sent: Mar 11, 2024 08:46 AM
it is only 10.04, 10.07 and 10.09 of API versions, (10.13 always support this API release...)
but yes, missing some dev and feature on pyaoscx (and ansible collections...)
Original Message:
Sent: Mar 07, 2024 06:31 AM
Hi all,
I'm building a small tool to deploy a vlan, EVPN configuration and VNI configuration under a vxlan interface. I'm running pyaoscx 2.5.1 but I have noticed that it still only supports versions 10.04, 10.07 and 10.09. It was last updated 4 months ago, but not much was changed according to Github.
I can't find any EVPN specific code in the package and this leaves me wondering if this package is still being actively maintained to any meaningful degree.
I use AFC with one of my customers and there one can easily use AFC to deploy a full EVPN BGP VXLAN network. I'm assuming that AFC doesn't use pyaoscx as it looks incomplete to me, but I'm happy to be proven otherwise.
Does anyone here have their own code using pyaoscx to create EVPN VNIs and VXLAN interfaces?
Cheers,
C
