VIA Certificate Installation
  • 1.  VIA Certificate Installation
    Posted 21 days ago
    I have a question about certificates for VIA.  My customer would like to get started using VIA, but we are a bit confused on what type of certificates to create and upload for VIA implementation.
    This is the information that I gave the customer:
    We need two certificates to upload into the controller group on Aruba Central.
     The VPNCs should have a server certificate signed by a CA that is trusted by the client devices to identify itself.
     We also need a Server certificate installed on the RADIUS server to terminate VIA clients EAP authentication.
    This is the question the customer came back with:
    Would two wildcard certs from our CA e.g. *.bordnamoan.com be sufficient or would you like it linked directly to the VPNC's/Radius server DNS? What format do you require the certs to be in and is a user/password required?
    Any assistance appreciated.
  • 2.  RE: VIA Certificate Installation
    Posted 21 days ago
    No, wildcard certificates should be used for EAP.  You should use a single cert per ClearPass node or a multi-SAN certificate with each of the ClearPass names/IPs in the SAN Field.
  • 3.  RE: VIA Certificate Installation
    Posted 15 days ago
    ... wildcard certificates should NOT be used for EAP...; or no wildcard certificates should be used for EAP. The recommendation builds on that and is what I would do as well.
  • 4.  RE: VIA Certificate Installation
    Posted 15 days ago
    Whoops typo… yes wildcard should NOT be used for EAP
