Virtual controller limited to 10AP's with Eval License
This thread has been viewed 23 times
  • 1.  Virtual controller limited to 10AP's with Eval License
    Posted Oct 17, 2022 01:58 PM
    I have installed a virtual controller and applied and eval license. The license is MC-VA-1K. When I added the license the controller reported that device and AP count is restricted to the platform limit of 10. I have not seen this before and as far as I know the eval is fully functional for 90 days. The eval description even says this itself.  Am I missing something?
  • 2.  RE: Virtual controller limited to 10AP's with Eval License
    Posted Oct 18, 2022 07:04 AM
    Found the issue - the VM did not have the correct resources in terms of CPU assigned. Added the correct number of CPU's and now it reports as MC-VA-1K
  • 3.  RE: Virtual controller limited to 10AP's with Eval License
    Posted 24 days ago
    Hi Smith, and what was the correct configuration of CPUs?
    Because I am having exactly the same problem
  • 4.  RE: Virtual controller limited to 10AP's with Eval License
    Posted 24 days ago
    The correct number of CPU/mem/disk (system requirements) is dependent on the size of appliance that you install (MC-VA-xxxx) and is listed in the virtual controller installation guide.
  • 5.  RE: Virtual controller limited to 10AP's with Eval License
    Posted 23 days ago
    Ok, THANK YOU VERY MUCH!
    I was not aware that this configuration had a direct influence on the limitations of the system in terms of the number of APs it could manage. I have revised the installation guide, corrected the hardware allocation and the "problem" has disappeared.
