Good day,
I have an Aruba 6300M with Firmware 10.05 and an Aruba 3810M with Firmware 16.10. Both are at different physical locations within a building, but are connected together over fiber.
Both are configured with their VLAN's identically with VLAN's 1, 3, and 7.
I set up some WIFI AP's that can broadcast 2 SSID's from VLAN 1 and 7, and I got them connected and working with the 6300M as the following from the interface: VLAN Mode: Trunk (Native Untagged) - VLAN: 1 - Trunk Allowed: 1, 7. I did this through SSH, but could also configure it through logging into the switch on a browser.
The SSH commands are not the same and the interface is completely different on a browser with the 3810M! I used the command 'VLAN trunk allow 1', 'VLAN trunk allow 7' on the 6300M but that does not work on the 3810M. Through research I thought maybe I needed to setup a Trunk, so I did create Trk1 but each time when I try to point the port/interface I want (eth-7) it doesn't include the additional VLAN. For instance at this moment, the VLAN table show's both VLAN 1 and 7 having port 7 Untagged, and Trk1 Tagged. However, eth-7 port has no connection to neither VLAN so something is setup wrong.
I had found and used a command-line interface guide for the 6300M, but could only find a management and configuration guide for the 3810M. It just doesn't have what I'm looking for (as far as I could find). Online research has lead to commands that just don't work either. I feel like I'm one or 2 simple lines of code away from what I need. Please help, and thank you.
