VLAN Pools and DHCP scope exhaustion
  • 1.  VLAN Pools and DHCP scope exhaustion
    Posted 27 days ago
    Hi
    I've just implemented VLAN Pooling for a client whose IP range does not, for various reasons, allow for one contiguous /21 to be assigned to their main wifi vlan. I've had to split out a few contiguous /24s and /23s from the /21 and define multiple (3) vlans on their switches (2930s and 2530s).
    The relevant bits from the instant config:
    vlan-name wifi-2
    vlan-name wifi-3
    vlan-name wifi-1
    vlan wifi-2 21
    vlan wifi-3 22
    vlan wifi-1 20
    and
    wlan ssid-profile "xxx Primary School"
    enable
    index 0
    type employee
    essid "xxx Primary School"
     wpa-passphrase xxx
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 20,21,22
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter arp
    g-min-tx-rate 11
    a-min-tx-rate 24
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
     max-clients-threshold 128
    The issue we're seeing is that clients seem to get allocated one of the three vlans just fine and lease an address from the DHCP server. But once that particular VLAN's DHCP scope is full the Instant controller doesn't seem to know about this and so the client simply can't lease an address and the user is left without Internet access. When I've implemented VLAN pooling on some other vendors equipment there has been an option to tell the wifi controller how many IP addresses are in the scope or set a maximum number of clients per vlan member of the pool. Is there anything like this with Instant (v8) otherwise I can't see the feature being of much use?
    Many thanks
  • 2.  RE: VLAN Pools and DHCP scope exhaustion
    Posted 27 days ago
    VLAN pooling is not recommended in general for WLAN (with Aruba). The recommended approach is to have a single VLAN and use broadcast/multicast control to avoid the reason that you have smaller subnets on most wired networks. What you describe would be expected as the AP does not track DHCP scopes, and due to the distributed nature of Instant APs, it would be hard to track if scopes are full. Also, IF you use pooled VLANs, make sure that all subnets are of an equal size as clients will be (more or less, statistically) equally distributed over the different VLANs. With unequal sizes, if one out of 3 VLANs runs out of the DHCP scope, one third (statistically) of new clients won't get an IP. With statistically, I mean that a 'hash' of the client MAC address is used to determine to what VLAN a client is assigned; this is one of the few methods that work in a distributed environment.
    I would go back to your customer and explain that not allowing /21s is breaking the design rules, wastes available IP addresses and results in the issues that you have seen. If you allocate 3x /21, it should be good, and if you stay below the maximum number of clients per VLAN (which may be what the customer tries to achieve/means), you'll get a similar result. But, I would just stay away from VLAN pooling unless you absolutely have to, and in that case design accordingly.
  • 3.  RE: VLAN Pools and DHCP scope exhaustion
    Posted 25 days ago
    Thank you for the information, Herman. I will go back and discuss with the customer and propose a new design.
    Best wishes
