SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
VPNC Retains configuration when moving from one group to other, why and how to wipe?
  • 1.  VPNC Retains configuration when moving from one group to other, why and how to wipe?
    Posted Mar 27, 2024 10:51 AM
    I am writing a 'step-by-step' process for a customer I am supporting for a RAP to Micro-branch conversion. While labbing it all out I created a new VPNC group from scratch. When I moved my "working" 9004 from the existing group, first to the default group and then to the new group, I was surprised most device-specific information moved over.
    I would like to start fresh instead of all this retained configuration.
    Two questions:
    1: Why is VPNC device configuration retained
    2: How do I wipe it all without doing it individually?
    The default group says it is AOS8
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: VPNC Retains configuration when moving from one group to other, why and how to wipe?
    Posted 29 days ago
    the group should be AOS10 if you are using gateways/VPNCs.
  • 3.  RE: VPNC Retains configuration when moving from one group to other, why and how to wipe?
    Posted 27 days ago
    Thank you Ariya,
    I will test that out. If understood correctly I create an empty group for ais 10 gateways and move existing gateways in there to wipe their configuration.
  • 4.  RE: VPNC Retains configuration when moving from one group to other, why and how to wipe?
    Posted 26 days ago
    yes and check if the configuration is synced up.
