Wired
last person joined: 11 days ago
VSX behaviour during role switch
  • 1.  VSX behaviour during role switch
    Posted Nov 08, 2023 10:42 AM
    due to a (possible firmware) issue our client is considering switching the roles of the switches in their VSX-cluster - e.g. turn primary into secondary and vice versa.
    This switch is supposed to happen during business hours, with a warning mail for the end users.
    My plan of action is as follows:
    • connect Laptop to USB-Console of Switch-01 (VSX-primary)
    • `shutdown` all ports on Switch-01 (-> ISL and Keepalive will go down here)
    • `no role` on Switch-01
    • connect to Switch-02 via SSH (VSX-secondary)
    • `role primary` on Switch-02 to turn it into VSX-primary
    • `role secondary` on Switch-01
    • `no shutdown` on all ports on Switch-01 (-> ISL and Keepalive should come back up here)
    Configuration of the VSX-primary is as follows:
    vsx
        system-mac 02:00:00:00:00:00
        inter-switch-link lag 10
        role primary
        keepalive peer 192.168.100.2 source 192.168.100.1 vrf vsx-keepalive
        vsx-sync mclag-interfaces vsx-global
    All VLANS are annotated with vsx-sync. Hence I expect all VLANs/MC-LAGs to automatically reestablish, even if they should get lost with the `no role` command.
    I'm interested (1) if anybody actually performed this and (2) whether this approach will cause interruptions in data-flow.
  • 2.  RE: VSX behaviour during role switch
    Posted Nov 22, 2023 12:07 PM
    Hi Mark,
    VSX switch roles do not indicate which device is forwarding traffic at a given time as VSX is an active-active forwarding solution. The roles are used to determine which device stays active when there is a VSX split, such as when the ISL goes down and for determining the direction of configuration-sync. If the VSX ISL goes down, the primary switch keeps forwarding traffic while the secondary switch blocks ports from participating in the VSX LAGs.
    You can swap the switch roles on the fly without shutting down ISL or Keepalive link.  ISL will go out of sync momentarily because now both VSX nodes will have same role (primary in below example)during this time. But as soon as you configure VSX peer with a different role(secondary), ISL will be in sync again in about 3secs.
    What happens when ISL link is down but keepalive is up
    VSX switches use their keepalive connection to determine that they are both up and running. Once that is determined, the user-configured primary VSX switch keeps its multichassis (VSX) LAG links up and the secondary VSX switch forces its VSX LAG links to go down with the appropriate reason. Once the ISL link is up, the MAC and ARP tables, LACP and STP states of the primary switch are synchronized to the secondary switch. Then, the configured delay timer starts. Once the delay timer expires, the secondary VSX switch brings up its VSX LAG links.
    1)VSX status on Secondary switch before switching VSX roles.
    8325-02# show vsx status
    VSX Operational State
      ISL channel             : In-Sync
      ISL mgmt channel        : operational
      Config Sync Status      : In-Sync
      NAE                     : peer_reachable
      HTTPS Server            : peer_reachable
    Attribute           Local               Peer
    ISL link            lag255              lag255
    ISL version         2                   2
    System MAC          0a:00:06:00:00:00   0a:00:06:00:00:00
    Platform            8325                8325
    Software Version    GL.10.10.1020       GL.10.10.1020
    Device Role         secondary           primary
    2)After changing secondary switch role to primary:
    8325-02(config)# vsx
    8325-02(config-vsx)# role primary
      ISL channel             : Out-Of-Sync
      ISL mgmt channel        : inter_switch_link_down
      Config Sync Status      : Out-Of-Sync
      NAE                     : peer_unreachable
      HTTPS Server            : peer_unreachable
    ISL link            lag255
    ISL version         2
    Platform            8325
    Device Role         primary             primary (Device roles inconsistent)
    3)Changing vsx peer role to secondary:
    ISL version         2                   2
    Platform            8325                8325
    Device Role         primary             secondary
    Hope this helps !
    Harkanwal
  • 3.  RE: VSX behaviour during role switch
    Hi Mark,
    You can swap the switch roles on the fly without shutting down ISL or Keepalive link.  ISL will go out of sync momentarily because now both VSX nodes will have same role (primary in below example)during this time. But after you configure VSX peer with a different role(secondary), ISL will be in sync again.
    1)VSX status on secondary switch
    ISL version         2                   2
    Platform            8325                8325
    2)VSX status on secondary switch after changing role to primary
    ISL link            lag255
    ISL version         2
    Platform            8325
    3)VSX status on secondary switch after changing VSX peer role to secondary
    ISL version         2                   2
    Platform            8325                8325
    Hope this helps !
    Harkanwal
