Wired Intelligent Edge
Weird syslog issue on 2930F switch
  • 1.  Weird syslog issue on 2930F switch
    Posted Jul 02, 2024 03:28 AM
    I am new to Aruba gear and have a lab with a 2930F switch backing a Fortigate 60F router.
    I recently added a Fortianalyzer VM appliance to serve as a log analyzer and syslog server for my lab. I have a bunch of devices flowing into the Fortianalyzer syslog ingestion, including a NAS, some Aruba APs, a proxy server, etc.
    Everything is working fine except for the 2930F. When I initially configured the 2930F to send logs to the Fortianalyzer, everything worked as expected. But when I checked on the Fortianalyzer a bit later, the 2930F showed down and that it hadn't sent any logs since ~20 minutes since I configured it.
    So, I ssh'd back into the 2930F to make sure I had written the config, etc. The config was fine, so I went back to the Fortianalyzer and, poof, it was back to sending logs. I chalked it up to gremlins and moved on. A while later, it's down again. After some thinking, the only thing I could figure is that logging into the 2930F somehow triggered it back into sending. So I logged back in and then refreshed the Fortianalyzer. Boom, back logging... Waited a bit, offline again. Confirmed it and now I am stumped.
    I can't find anything online relating to this. Just a bunch of threads with people successfully configuring the 2930F to send to a syslog server, just like I did, none mentioning anything special required to make it continue sending logs.
    I am guessing it's something simple, but I am at a loss.
    Thoughts?
  • 2.  RE: Weird syslog issue on 2930F switch
    Posted Jul 02, 2024 03:31 AM
    Could it be that there just aren't any log events during the time it's silent? If you log in, that triggers a log message, further link states (ports going up/down), config changes. In a stable network there may just not be too many log messages.
    With the command 'show syslog statistics' you can check how many logs (and which category) are sent from the switch.
  • 3.  RE: Weird syslog issue on 2930F switch
    Posted 30 days ago
    Turns out that I was incorrect, that logging in via SSH triggered it to start sending logs again.
    I just did a step by step test.
    1. Log-in via SSH - No joy on FAZ
    2. Run Conf t - No joy
    3. Run Show logging - No joy... But I was able to dispel the notion that the disconnect is due to no logs generated. There are consistently some logs every couple of minutes, max, going back days.
    4. Run Logging [ip_addr] udp - No joy. I would have thought this would trigger it for sure but it didn't this time.
    5. Run Show logging syslog - No joy. But did confirm it's configured to talk to the right place with the correct protocol.
    6. Run Logging facility all-pass - That triggered a reconnect
    7. 15 minutes later, shows down again.
    Even leaving it overnight, it still shows no logs reported since whatever was done to trigger a reconnect. And that doesn't jive with what logging on the switch shows.
    Still, you may be onto something. It could be that the logs aren't leaving the switch for some reason, or this may just be an oddity with Fortianalyzer. It's just strange that this switch has a NAS, Hyper-V host with 9 VMs, 2 Aruba AP345s and a bunch of other random devices plugged into it (including this PC) and all of them are live devices. There's always something going on. And most of that infrastructure is also logging to the FAZ without issue.
    Fortianalyzer treats no logs received after 15 minutes as the device being down, and so it shows it as such in the portal. I feel like there is something I am missing here. I was hoping someone else had experience with a similar setup to compare to.
    I will keep plugging on it and report any new findings here for historical purposes.
    Thanks.
  • 4.  RE: Weird syslog issue on 2930F switch
    Posted 16 days ago
    For anyone finding this post, I found the solution. For whatever reason, the only way the switch will continue to show as an active device in Fortianalyzer after the initial connection is if the logging facility on the switch is set to syslog. Other facilities will connect and send logs but will become inactive after a few minutes and cease reporting.
    switch# conf t
    switch(config)# logging facility syslog
    switch(config)# end
    switch# write mem
