Aruba Central
What is difference between airwave and aruba central
This thread has been viewed 27 times
  • 1.  What is difference between airwave and aruba central
    Posted Apr 26, 2024 11:20 AM
    Can we push template from aruba airwave in aruba switch  also
    and What is difference between airwave and aruba central
  • 2.  RE: What is difference between airwave and aruba central
    Posted 30 days ago
    Yes, you can push a template into Aruba AOS-CX or ArubaOS switches.
    Main difference between Airwave and Central is that Airwave is the legacy on-premises management system, where Central is a modern cloud-based management system for Aruba equipment that can run 'as a service' in the cloud, or on-premises (Central On Premises).  Please reach out to your local Aruba partner or Aruba sales team if you need to know what is best for your environment.
  • 3.  RE: What is difference between airwave and aruba central
    Posted 29 days ago
    To add on what Herman wrote. Central is very capable and modern cloud or on prem management system for Aruba gear. It help you automate and optimize your Aruba Network environment. With very rich REST API you can integrate it into your environment for example if you use Ansible for network configuration, you have ansible module ready for integration with Central. If you use cloud version, you have no worries about maintaining  the underlying infrastructure.
    The drawback for now (my point of view) is, that it support Aruba Network gear only. You wont be able to manage 3rd party equipment. And sometimes can become slow to respond.
    AirWave on the other side is on prem solution. I use it extensively and like it very much. It is multivendor and does integrate with other vendors very nicely. It's primarily WiFi oriented, but handle switches and routers well.
    Drawback is that you need to maintain underlying environment and it lacks all advanced features that Central is getting on regular basis like AI, NetConductor,...
    So it really depend on your needs and preferences. .
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
