The role the client is assigned to shouldn't block anything that would cause the issues we're seeing (in theory) has 7k other clients utilize the same role and can connect. this week it's just been 3 clients a MacBook-Pro and 2 android devices.
From the lease logs on the linux server the only thing that sticks out is the UID being different from working clients.
lease 172.17.75.118 {
starts 5 2022/09/16 14:08:50;
ends 5 2022/09/16 14:10:50;
cltt 5 2022/09/16 14:08:50;
binding state free;
hardware ethernet 3c:06:30:25:1b:3c;
uid "\001<\0060%\033<";
client-hostname "MacBook-Pro-2";
I can't figure out how to clear a single dhcp lease in linux for the life of me coming from a windows server background.
I found this thread
https://community.arubanetworks.com/browse/articles/blogviewer?blogkey=504044b0-f16b-4688-bfa9-9a3a24331298 which goes over promiscuous option and changing that value to one. However the difference is they're running a VMC where we run physical 7240xm's but our DHCP server is in VMWare without that enabled be curious if that's why we see so many dhcp messages from multiple sources.
Then I'm assuming there is no way to see if those dhcp messages are being sent through the AP between client/controller because you can't ssh into them so I would have to console into an AP to see if there are any logs there correct?
Thank you,
Eric Berg
Original Message:
Sent: Sep 16, 2022 10:46 AM
Subject: Wireless Clients/DHCP issues/AP 315
You can run packet (datapath) captures from the controller as well, but I would start from the client. If the packet is not sent there, you'll have to search in the client, if it is sent but not arriving on the DHCP server, you will need to go step by step to find out where the packet is lost.
Does the role that the client is assigned to block anything? Any ACLs/Firewalls in between the client and the DHCP server?
Original Message:
Sent: Sep 16, 2022 09:24 AM
Hi Herman,
Thinking the same thing not looking good on the DHCP side - It's hard to get a hold of the client machines experiencing the issue to run pcaps on them. Is there anything that can be run on the mobility master or wireless controllers that could see the DHCP request and where that's getting lost or if the offer is reaching the client? We have 11k clients and only 3 or 4 have experienced the issue this week where they don't get a DHCP Request back but you can see the Discover/Offer messages from our linux dhcp server. So majority of our clients are fine which means the ones having issues should be able to reach the DHCP server as well. I'm just wondering if something is getting goofy on our linux dhcp server with 11k clients trying to get an address from that one DHCP server/IP helper-address on the core.
I will have to try doing some pcaps to see the result at the clients
Thank you,
Eric Berg
Original Message:
Sent: Sep 16, 2022 09:07 AM
Does not look good to me. What do you see if you run a packet capture (like Wireshark) on the client? Do you see the DHCP Offer there? And if so do you see a DHCPREQUEST then? Is the client able/allowed to reach the DHCP relay (that is probably the IP on the core where you configured the ip-helper) and server for its DHCP request and renews?
Original Message:
Sent: Sep 15, 2022 03:53 PM
Having issues with wireless clients windows/MAC and getting DHCP - DHCP ip-helper on core switches pointing to CentOS Linux DHCP server
We can see the Discover/Offer but no Request/Acknowledgement - This is from a specific 315 series
Sep 15 13:21:36 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:21:36 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:21:36 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:36 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:38 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:38 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:38 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:21:38 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:21:43 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:43 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:21:43 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:21:43 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:39 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:40 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:40 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:40 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:40 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:43 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:43 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:43 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:43 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:47 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:47 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:47 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:47 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:56 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:56 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:49:56 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:49:56 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:50:04 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:50:04 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 13:50:04 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 13:50:04 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.252
Sep 15 14:05:16 wlandhcp dhcpd: DHCPDISCOVER from 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Sep 15 14:05:17 wlandhcp dhcpd: DHCPOFFER on 141.233.75.118 to 3c:06:30:25:1b:3c (MacBook-Pro-2) via 141.233.79.253
Also it seems clients getting the full DHCP handshake are continuously going through that process - Is that normal? This is from multiple clients different AP models as we have 205, 205h, 215, 224, 225, 303, 315, 325, 503h, 505 running on 7240xm cluster
Sep 15 07:50:12 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:50:13 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:50:14 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:50:14 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:50:14 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:50:14 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:32 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:32 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:32 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:32 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:50 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:50 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:52:50 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:52:50 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:53:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:53:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:53:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:53:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:53:45 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:53:45 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:53:45 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:53:45 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:09 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:09 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:09 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:54:09 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:54:34 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:34 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:34 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:54:34 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:54:35 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:35 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:54:35 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:54:35 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:57:48 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:57:48 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:57:48 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:57:48 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:58:01 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:58:01 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:58:01 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:58:01 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:58:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:58:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:58:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:58:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:00 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:00 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:00 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:00 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:31 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:31 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:31 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:31 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:56 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:56 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 07:59:56 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 07:59:56 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:00:36 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:00:36 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:00:36 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:00:36 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:08 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:08 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:08 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:08 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:44 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:44 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:44 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:44 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:59 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:59 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:01:59 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:01:59 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:05:35 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:05:36 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:05:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:05:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:05:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:05:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:10:54 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:10:54 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:10:54 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:10:54 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:16:13 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:16:13 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:16:13 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:16:13 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:16:31 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:16:31 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:16:31 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:16:31 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:20:09 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:20:09 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:20:09 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:20:09 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:22:21 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:22:21 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:22:21 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:22:21 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:24:17 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:24:17 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:24:17 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:24:17 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:24:29 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:24:29 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:24:29 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:24:29 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:25:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:25:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:25:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:25:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:26:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:26:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:26:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:26:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:27:15 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:27:15 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:27:15 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:27:15 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:28:41 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:28:41 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:28:41 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:28:41 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:29:07 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:29:07 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:29:07 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:29:07 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:29:34 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:29:34 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:29:34 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:29:34 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:31:04 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:31:04 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:31:04 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:31:04 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:31:17 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:31:17 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:31:17 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:31:17 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:32:28 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:32:28 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:32:28 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:32:28 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:33:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:33:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:33:37 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:33:37 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:34:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:34:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:34:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:34:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:37:20 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:37:20 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:37:20 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:37:20 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:39:11 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:39:11 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:39:11 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:39:11 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:39:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:39:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:39:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:39:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:41:24 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:41:24 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:41:24 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:41:24 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:41:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:41:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:41:49 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:41:49 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:42:32 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:42:32 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:42:32 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:42:32 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:43:13 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:43:13 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:43:13 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:43:13 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:44:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:44:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:44:26 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:44:26 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:44:40 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:44:40 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:44:40 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:44:40 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:45:01 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:45:01 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:45:01 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:45:01 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:45:55 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:45:55 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:45:55 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:45:55 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:46:43 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:46:43 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:46:43 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:46:43 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:49:22 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:49:22 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:49:22 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:49:22 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:50:03 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:50:03 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:50:03 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:50:03 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:51:16 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:51:16 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:51:16 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:51:16 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:51:44 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:51:44 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:51:44 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:51:44 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:52:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:52:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:52:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:52:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:54:47 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:54:47 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:54:47 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:54:47 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:56:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:56:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:56:30 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:56:30 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:56:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:56:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:56:42 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:56:42 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:58:45 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:58:45 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:58:45 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:58:45 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:59:02 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:59:02 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 08:59:02 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 08:59:02 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:00:05 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:00:05 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:00:05 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:00:05 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:03:19 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:03:19 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:03:19 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:03:19 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:19:47 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via ens160
Sep 15 09:19:47 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via ens160
Sep 15 09:33:43 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:33:43 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:33:43 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:33:43 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:12 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:12 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:12 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:12 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:16 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:16 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:16 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:16 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:38 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:38 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:38 wlandhcp dhcpd: DHCPDISCOVER from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:38 wlandhcp dhcpd: DHCPOFFER on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:39 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:39 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:35:39 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 (141.233.160.16) from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:35:39 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:36:00 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:36:00 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.252
Sep 15 09:36:00 wlandhcp dhcpd: DHCPREQUEST for 141.233.106.77 from 8e:3a:2e:95:65:60 via 141.233.111.253
Sep 15 09:36:00 wlandhcp dhcpd: DHCPACK on 141.233.106.77 to 8e:3a:2e:95:65:60 via 141.233.111.253
Is it possible to much client load on one DHCP server - 11k clients
