WPA2 Enterprise on IAP315, works only on conductor
  • 1.  WPA2 Enterprise on IAP315, works only on conductor
    Posted 30 days ago
    Hi
    I have 4 Aruba 315 managed bei a virtual controller. Firmware 8.12.0.0 SSR.
    I configured one network using wpa2-enterprise, I have my radius server, I have configured such things on many vendors for clarity, here also everything works but only on conductor. When I switch to another access point, it is no longer possible to connect. Why?
  • 2.  RE: WPA2 Enterprise on IAP315, works only on conductor
    Posted 30 days ago
    You've probably either not enabled dynamic RADIUS proxy or not added the other IAPs as network devices in your RADIUS server.
    Carson Hulcher, ACEX#110
  • 3.  RE: WPA2 Enterprise on IAP315, works only on conductor
    Posted 30 days ago
    >or not added the other IAPs as network devices in your RADIUS server. - that's the answer, everything works now, thank you very much!
