WPA2 Enterprise on IAP315, works only on conductor
  • 1.  WPA2 Enterprise on IAP315, works only on conductor
    Posted Apr 02, 2024 09:48 AM
    Hi
    I have 4 Aruba 315 managed bei a virtual controller. Firmware 8.12.0.0 SSR.
    I configured one network using wpa2-enterprise, I have my radius server, I have configured such things on many vendors for clarity, here also everything works but only on conductor. When I switch to another access point, it is no longer possible to connect. Why?
  • 2.  RE: WPA2 Enterprise on IAP315, works only on conductor
    Posted Apr 02, 2024 10:29 AM
    You've probably either not enabled dynamic RADIUS proxy or not added the other IAPs as network devices in your RADIUS server.
    Carson Hulcher, ACEX#110
  • 3.  RE: WPA2 Enterprise on IAP315, works only on conductor
    Posted Apr 02, 2024 02:59 PM
    >or not added the other IAPs as network devices in your RADIUS server. - that's the answer, everything works now, thank you very much!
