Q:
How do you configure SNMPv3 (and credentials) for ArubaOS-Switches?
ASE Link: Go to the solution
A:
This solution will configure SNMPv3 credentials on a switch running ArubaOS-Switch (or the legacy ProVision OS).
Minimum version varies by switch model; should work on any ProCurve/ArubaOS-Switch device running 15.13 or newer.
This solution will configure SNMPv3 credentials, including user accounts, groups, and SNMP options.
Aruba 2530 running YA.16.01.0004
[1] HPE ArubaOS-Switch Software Management and Configuration Guide K/KA/KB.16.01
