You can use port mirroring to take a copy of the ingress and egress packets on one or more ports. Packets are sent to the destination without modification at Layer 2. Any number of network ports can be configured for monitoring. Port-channel can also be the source for mirroring. If the bandwidth for the source is greater than the destination, packet loss can occur. The Mobility Access Switch does not distinguish whether the source port is a Layer 2 access or a trunk interface.
Aruba Mobility Access Switch S1500-24P-US, Version 7.2.2.0
None
[1] Aruba MAS 7.3.0 User Guide
