Campus Switching and Routing
2930M routing problems
Hope someone can help me with the next problem.
We got a stack of 2930M switches.
All is configured well, and tested well.
But now we want to route from the WAN (a IPVPN) to devices/switches which have the gateway pointed at the 2930M.
This is not working well.
case info:
2930 VLAN 99: (GW of the network)
WLC7205 VLAN 99: (GW
the 2930 has a transit to a router, the IP of the router is and the IP of the switch is
ip routing and ip route is in place.
When i connect from a client (in this case a SSL VPN user) to the and everything is working fine.
When i connect to it won't work and the last hop in a traceroute will be
I created a TAC case because i thing this is a problem in de routing core/table of the switch. But maybe there are some smart minds on here which can help me solve the problem.
Re: 2930M routing problems
I found the problem in the router before the switch
