Campus Switching and Routing
ARUBA SWITCH AND IP PHONES
How can i make us of the aruba switch 3810M to make it function with my IP Phone using VLAN10 for voice to talk to the IP PABX and with my PC data in vlan20.. vlan20 is good and configured already workstations can talk to servers.IPSSSS.pngHOW TO CONFIGURE THE SWITCH?
Frequent Contributor I
Re: ARUBA SWITCH AND IP PHONES
We have done this in the past a couple of times. What you can do is to create a sort of hybrid port by setting the voice vlan (10) as tagged on the switch port while the data vlan (20) is untagged. It depends on your IP telephone model maybe. We use Cisco phones, and it worked for us.
right now the ports are untagged to vlan20 the data vlan, but we are planning to use that for ip phones as well since we have created a voice vlan on the switch. do i need to specify the port settings as "hybrid" or only by tagging the ports to voice vlan..
Port config like this should do it:
interface 1
   tagged vlan 10
   untagged vlan 20
It's been a few years since we did this, so I cannot say if it works under newer ArubaOS versions. An alternative would be to use 802.1x.
any body from aruba switching engineering team can help me here because i have to deploy this to my customer and i need assistance from you guys, please
I tested this yesterday on a 2530 with ArubaOS 16.04.0008, and it worked fine. The Cisco IP telephone got a DHCP address in the tagged (voice) vlan, and the laptop connected to the PC port on the phone got a DHCP address in the untagged vlan. I've had it connected like this for 24 hours without any problems.
thank you! by the way do i still need to do the qos command for the voice vlan? qos priority? and also is 3810M aubra switch supports an IP Phone panasonic?
If your switch supports vlans, and can be configured with a tagged and untagged vlan on an interface, it should be compatible with most or all IP Phones.
Typically, the phone will either be configured manually to use the voice vlan, or will recieve (initially on the data vlan) an option from DHCP that will let it know what vlan it should start tagging things with. Once it starts tagging things with the voice vlan, the switch only needs to support vlan tagging.
One gotcha that I've found with Aruba switches is that by default when you enable LLDP the lldp tlv "network_policy" will be enabled. With that TLV enabled, and a "voice" vlan configured, a lot of phones will ignore what they get from DHCP in favor of what they get from there. That works fine, if you have configured it to hand out what they need, but if you prefer to use dhcp, make sure and use "no lldp config <port-range> medTlvEnable network_policy" (assuming that doesn't interfere with anything else)
Contributor I
For QoS
switch(config)# qos type-of-service diff-services
switch(config)# vlan 10
switch(vlan-10)# voice
If you want to apply something more specific use this old but good thread
https://danielkuchenski.wordpress.com/2013/12/20/hp-switch-provision-qos-guide/
If it helps please add Kudos
