Campus Switching and Routing
About BPDU protection feature
Hi experts,
I have two doubts about this feature:
  1. I saw the BPDU protection feature is enabled on a per-port basis with the command "spanning-tree <port-list> bpdu-protection". Cisco has the command "spanning-tree portfast bpduguard" which allows to enable the feature in all the portfast ports at the same time. Is there any command to enable this feature in all auto-edge ports at the same time in Aruba?
  2. When this feature is enabled, is the port disabled always it receives a BPDU or only when it receives a better BPDU?
Julián
Re: About BPDU protection feature
Greetings!
Addressing your questions in order:
  1. ArubaOS-Switch allows configuration of BPDU protection on a per-port basis only; we do not have an equivalent to the command you provided. I will provide feedback to engineering.
  2. BPDU protection will shut down a port if any BPDU is received.  To cause a port to shut down only when a superior BPDU is received, you would instead use the root guard feature, which is configured in a nearly identical manner to BPDU protection:
switch(config)# spanning-tree <port-list> root-guard
Matthew Fern | Technical Marketing Engineer, Campus Networking
Aruba, a Hewlett Packard Enterprise Company
Hi Matthew,
Many thanks, very clear :)
Julián
