Campus Switching and Routing
Occasional Contributor I
Aruba 2930 - Radius setup
Hi all,
I'm setting up a 2930 switch in combination with Clearpass.
I applied following config:
radius-server host 192.168.1.1 key test
radius-server host 192.168.1.1 dyn-authorization
radius-server host 192.168.1.2 key mhCP6RjWBCsFxRnWXiWRT67yFZOYLgaF
radius-server host 192.168.1.2 dyn-authorization
aaa authentication mac-based chap-radius
aaa authentication port-access eap-radius
aaa port-access authenticator 1/10 unauth-vid 290
aaa port-access mac-based 1/10 unauth-vid 290
aaa port-access authenticator active
When I check the Radius requests, i still see 0. Looks like no requests are being sent by the switch. What do I do wrong?
Authentication UDP Port : 1812 Accounting UDP Port : 1813
Round Trip Time : 0 Round Trip Time : 0
Pending Requests : 0 Pending Requests : 0
Retransmissions : 0 Retransmissions : 0
Timeouts : 0 Timeouts : 0
Malformed Responses : 0 Malformed Responses : 0
Bad Authenticators : 0 Bad Authenticators : 0
Unknown Types : 0 Unknown Types : 0
Packets Dropped : 0 Packets Dropped : 0
Access Requests : 0 Accounting Requests : 0
Access Challenges : 0 Accounting Responses : 0
Access Accepts : 0
Access Rejects : 0
Kind regards,
Re: Aruba 2930 - Radius setup
Did you follow the ClearPass Solution Guide for Wired Policy Enforcement?
Tim Cappalli | Aruba Security
You haven't enabled 802.1X and MAC Auth on the ports which are the commands:
aaa port-access authenticator 1-7
aaa port-access mac-based 1-7
without any subcommands. As Tim suggested, I would follow that guide as it has all needed commands and best practices in it.
Regular Contributor I
Always follow the guide!!
It helps you!
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
