Campus Switching and Routing
Occasional Contributor I
Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
Hi Guys (and of course girls),
I'm a little bit stuck in an IRF-Configuration and i hope you all somehow can help me a little.
I've set up an IRF-Stack of 6x HPE 5700AF Switches with a 20GBit/s IRF-Link as a Ring. To prevent Split-Brain-Situation i wanted to set up LACP-MAD with an assist device. (customers wish for a seperate device...)
Here I wanted to use one Aruba 2930F Switch with 3x 1G RJ45 Ethernet for the local Stack-Members and 3x 1G SFP-Fiber for the remote devices (different building about 650ft/210m away).
I actually don't know how to set those devices correctly up.
Right now i created a Link-Aggregation on the IRF with 6 member ports an the MAD-VLAN 3999 as access ports. On the 2930F i created a lacp-trunk with 3 copper and 3 fiber ports and the same access-vlan.
Here is the moment where i got stuck.
On the a-Series Switch stack i activated lacp-mad.
But what to do on the Aruba switch?
Maybe someone can support me with a corerct mad-Config on the A-series switch and a correct assist-config for the 2930F device...
Would be nice.
Any idea appreciated!
Franz
Contributor I
Re: Aruba 2930F assist LACP-MAD assist for 6x HPE 5700 40XG IRF
At the comware switch configure a dynamic link-aggregation interface. In the bridge interface enter the command “mad enable”.
At the 2930f switch create a trunk interface with lacp. Within the trunk interface enable mad passtrough. For example: “interface trk1 lacp mad-passthrough enable”
To validate the passtrough use the command “show lacp mad-passthrough counters”
To validate if mad is working enforce a split brain.
Willem Bargeman
ACMX#935 | ACCX #822
Believe it or not. I had configured all correct. It did already work.
I just missed the command "show lacp mad-passthrough" as only this showed me (and the customer) that it was already working.
The Comware-Switches told us already that MAD was doing OK and all the members were seeing each other...
THANK You for saving my day
BTW: Will this work with an HP/Aruba 2920 as well? At least in the Documentation it says something about mad-passthrough...?
I think this will also work for the 2920 switches
THX
