Campus Switching and Routing
Aruba 3810M - Configure High Availability without Stacking module
I have two Aruba 3810M 48 port switch which is using for server connectivity. We recently purchased this switch and it's running version KB.16.02.0016.
We don't have stacking module but we installed flexible-module A type JL083A.
Help me to configure the high availablity using this two switch. Which protocol need to use to enable HA.
I want to enable failover for server connectivity.
Occasional Contributor I
Re: Aruba 3810M - Configure High Availability without Stacking module
Without the stacking module, the switches can not be managed as one logical switch.  However, HA for server connectivity could be acheived using distributed trunking, potentially.  Switches would still be managed independently, though.  More information on DT can be found here:  http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/K-KA-KB/15-18/5998-8160_ssw_mcg/content/ch04s14.html
I would highly recommend purchasing some stacking modules and creating a stack, though, as opposed to using DT, if at all possible.
Best,
JJ
Thanks for your info, will check further
Contributor I
Maybe you can enable VRRP (Virtual Router Redundancy Protocol) between the switches so each has an static IP address and they share a virtual IP address to whom the servers responds as the default gateway.
The drawback of this is that there is no link aggregation only HA between both switches.
The config is something like this and you can obtain further info at the manual HPE ArubaOS-Switch Software Multicast and Routing Guide for
K/KA/KB.16.03 page 247
# enable protocol
ip routing
router vrrp ipv4 enable
interface vlan <vlan #>
  ip address <static vlan ip> <mask>
  vrrp vrid <ID #>
  virtual-ip-address <virtual ip address>
  priority <priority # to define which switch will be the primary one>
  preempt-mode
That config must be applied on both switches with different static ip addresses and priorities.
Hope it helps!
If it helps please add Kudos
