Campus Switching and Routing
Super Contributor II
Aruba 3810M (JL076A) support JL085A power supply
Hey Airheads. I was wondering if you guys knew if a JL085A power supply will work in a Aruba 3810M (JL076A)?
The data sheet here (p11) says the (JL076A) Must have JL086A or JL087A power supply. Do you know if it would even bootup with a JL085A power supply instead?
Sean Rynearson
Re: Aruba 3810M (JL076A) support JL085A power supply
Hi Sean,
This will not work. All the POE power supplies are keyed to not fit in non POE switches and vica versa.
Let me know if this answer helps you and if you have any other questions.
Regards, Dobias
rzz
Contributor II
it will not work base on the configurator
Thank you
Sean Rynearson
Thanks man! I figured. But its ok, I just ordered two JL086A power supplies. Those will work :-)
Sean Rynearson
You're welcome!
Met vriendelijke groet / Kind regards,
[ruba-hp-signature-2_160x105.jpg]
Dobias van Ingen
EMEA CTO and SE Director
UC & C: + 31202450591 | M: +31 651 785440 | @networkingdvi
Startbaan 16 | 1187 XR Amstelveen | Netherlands
WWW.ARUBANETWORKS.COM<> | FOLLOW US | Twitter<> | LinkedIn<>
