Campus Switching and Routing
Aruba Switch Provision via ZTP (Airwave)
I am provisioning Aruba 24 and 48 ports switches via Airwave ZTP. Everything is working as expected but Airwave doesn't provide the option to select the template for 24 or 48 ports switch rather it only ask for switch series. Due to this I am unable to provision 24 and 48 ports switch together using a different template. Is there any solution or workaround available?
