Campus Switching and Routing
Frequent Contributor II
Aruba Switch S1500
does Aruba Switch S1500  support Stacking ?
it is not mentioned @ its datahseet & no DAC cables exiets at part numebrs
while for S2500 , it is mentioned & DAC cables exists
Re: Aruba Switch S1500
The S1500 supports stacking with AOS 7.3 code. The S1500 does not have 10G uplink ports so SX, LX, TX  SFPs must be used for stacking.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
You can stack the S1500 but only with other S1500s...FYI
The S2500 and S3500 can be stacked together
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
If you found my post helpful, please give kudos
