Campus Switching and Routing
Frequent Contributor II
Aruba Switches RIP Protocol
Aruba switches supports OSPF
does it support RIP ?
Re: Aruba Switches RIP Protocol
Static routes, OSPF and PIM
Tim Cappalli | Aruba Security
Strange to support OSPF without supporting RIP
Aruba
Telnet-1,
When developing our L3 feature set, a majority of our customers requested OSPF as opposed to RIP for their campus deployments. The two protocols share little to nothing in common so adding RIP would be a separate development effort. If you would like to see RIP, I would recommend submitting the request to our idea portal.
https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
Best regards,
Madani
Occasional Contributor I
This is so very late since the question was posted, however, this may help others who might have the same question.
YES, aruba switches do support RIP. e.g. 2620, 2920, 3800 series and more.
Contributor II
Hi Ahsan,
Yes the current ArubaOS-SW switches like the ones you mentioned support RIP.
But this post was from 2013, back then Aruba and HPE were not one company. So the post was about the legacy Aruba switches and as Madani stated those didn’t support RIP.
Hope this helps
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
