Campus Switching and Routing
Occasional Contributor I
Aruba switch stack licensing in tunnel node
Hi All,
In tunnel node 4 2930M/F switches are stacked, so there are 4 physical switches and it is 1 logical switch group.
Question is that how many license are needed on the controller 4 or 1 license?
Thank you.
Contributor I
Re: Aruba switch stack licensing in tunnel node
From a controller perspective stacking switches are considered as one switch. Therefore one license is needed for the "Per Port Tunneled Node" feature. Currently there are no licences needed for the "Per User Tunneled Node" feature.
Frequent Contributor I
Is there any official documentation about that?
Thank you in advance for your answer!
Zs
I read the ClearPass Solution Guide for Wired Policy Enforcement by Tim Cappalli and found myself asking the same question about per-user tunneled-node.  It clearly states that a switch stack consumes 1 license for per-port tunneled-node but then says nothing about the impact for PUTN.  I set up PUTN and saw no licenses used according to MM so I came out here looking for validation.  Thanks for your post and I hope this is included in future versions of the documentation.
Contributor I
For PUTN there is currently no license enforcement. This may change in the future.
