Campus Switching and Routing
Auto configuration upon Aruba AP detection - 2540
Hi All,
Does anyone have a list of the elements of auto config that are supported by the 2540? The feature was release in FW16.01 which i think was before 2540 so it isnt mentioned like others that dont support certain elements like egress rate limit.
Re: Auto configuration upon Aruba AP detection - 2540
Greetings!
Here are the specific parameters you can configure as part of a device profile (including the default AP profile) on the 2540:
 allow-jumbo-frames    Configure jumbo frame support
for the device port. cos Configure the Class of Service (CoS)
priority for traffic from the device. egress-bandwidth Configure egress maximum bandwidth
for the device port. ingress-bandwidth Configure ingress maximum bandwidth
for the device port. poe-max-power Configure the maximum PoE power for
the device port. poe-priority Configure the PoE priority for the
device port. speed-duplex Configure the speed and duplex for the
device port. tagged-vlan Configure this port as a tagged member
of the specified VLANs. untagged-vlan Configure this port as an untagged
member of specified VLAN.
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
