Campus Switching and Routing
Super Contributor II
Basic getting started manual for ArubaOS ( switches)
Just about to start playing with some Aruba Switches ... downloaded the ArubaOSS 7.4 CLI manual (740 pages) and the ArubaOS 7.4 User Guide (462 pages)
Isn't there any smaller . document ... like "getting started" thart I can use to at leastr get n ip address into the switch before I strt looking at ZTP and all the interesting stuff?
A
Re: Basic getting started manual for ArubaOS ( switches)
Lots of them popped up when I googled it..
Here's the 2930F getting started guide for example: http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c05163011-2.pdf
Cheers
James
Also, just to be clear, AOS 7.4 is the old mobility access switch line, not ArubaOS-Switch.
Tim Cappalli | Aruba Security
