- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Default STP out of the box
01-23-2018 07:22 AM
If i have a 3800 switch for example.
By default spanning tree is disabled.
If i enable it by just entering "spanning-tree", what version of STP is enabled?
Is it always MSTP with only instance 0 preconfigured to handle all VLANs, waiting for me to create new instances?
Or is it RSTP or even CSTP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Default STP out of the box
01-23-2018 04:01 PM
Hi Pepe,
The ACMA Official Certification Guide says that running that command you woud enable RSTP, but the HPE ArubaOS-Switch Advanced Traffic Management Guide K/KA/KB.16.01 is not clear about this. I would like someone with experience on this clears this doubt.
Julián
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-23-2018 05:05 PM
Hello!
By default the switch does not have STP enabled, and when enabled, it will current as MSTP but with RSTP behavior because it does not have a configured instance.
|ATP FLEXNETWORK V3|ACSA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-23-2018 09:11 PM
Hi John,
Is there any command to just enable RSTP or the only way is enabling MSTP without configuring any instance as you say?
Julián
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-24-2018 01:04 AM
Is there a document which states for which physical switch series this applies to in combination with which firmware?
So basically you could say it's RSTP out of the box, with the OPTION to configure multiple instances.
If the output shows this:
# sh span
Multiple Spanning Tree (MST) Information
STP Enabled : Yes
Force Version : MSTP-operation
I can assume my switch is running at least MSTPI0/RSTP (instead of CSTP)?
For instance 0 you can't/don't need to define a config revision/name etc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-24-2018 03:14 AM
If you want to do the Vlans balancing which is the main feature of MSTP, you need to create the instances (1..2..3) and associate Vlan. This process must be done on all switches. This becomes complex when you have a significant amount of switches.
With the current configuration, MSTP + INSTANCE 0, the switch will behave as RSTP and you will have a free network of L2 loops
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
