Campus Switching and Routing
Occasional Contributor I
Does Aruba switch have motd banner?
Hi All,
Does Aruba switch have motd banner? If yes, what's the command to do it?
Re: Does Aruba switch have motd banner?
banner motd <delimiter> <banner text> <delimeter>
Tim Cappalli | Aruba Security
Thanks cap, will try it out tomorrow
Contributor II
Is there any way to center text or image created with symbol in Banner motd? I tried blank space and it doesn't work.
mathieuc,
Just use quotes:
banner motd ^
"*     Access to this computer system is restricted to       *"
"*     official use by users authorized by Corp Inc.,        *"
"*     and must comply with the Information Security         *"
"*     policies listed on the Corp Corporate Intranet at:    *"
"*     http://iweb/informationsecurity/documents/            *"
"*     policies/Policy.htm                                   *"
"*     Corp may monitor and disclose information on or       *"
"*     about this system, and you should have no             *"
"*     expectation of privacy in using it.                   *"
"*     Your continued use of the system constitutes          *"
"*     agreement to these terms. If you do not agree,        *"
"*     please disconnect immediately.                        *"
Valued Contributor II
We can configure the motd banner in Aruba gear, use the following commands.
(config) #banner motd #
Enter TEXT message [maximum of 4095 characters].
Each line in the banner message should not exceed 255 characters.
End with the character '#'.
( Type your banner here )
Welcome to Aruba #
(To preview your banner )
(config) #show banner
Welcome to Aruba
Hope answered your question :)
Cheers,
 Venu Puduchery
Cheers,
Venu Puduchery,
Contributor II
Thanks cjoseph!
It work with the quotes. Text is now keeping the centered formating.
I don't see it on the GUI login screen though. If I remember when I did my test without the quote I saw it but not now with the quote...
A bug maybe?
(I'm running on v6.4.1.0 and waiting 6.4.3.0)
definitely a bug.  Let me see when that can be fixed...
Contributor II
Any update on the bug?
I'm waiting 6.4.3.0 to upgrade all my controlle for a couple of other bug. Does someone in developpement know if this issue might be fixed in this version?
Aruba
I'm running 6.4.2.2 on my 7200 and see the banner in the WebUI.
What bugs fixes are you waiting for in 6.4.3.0? That feature release is still under engineering development and testing.
Best regards,
Madani
