Campus Switching and Routing
Download firmware for Aruba Switch 2920
Where I can find the firmware for this switch model or any Aruba switch model. I cant find a single firmware for this switch.
Thank you
Re: Download firmware for Aruba Switch 2920
I have found the following site to be the easiest to download firmware/software for any ArubaOS-Switch or HPE prodcuts.
https://h10145.www1.hpe.com/downloads/ProductsList.aspx
Just enter the product number or description, and it will take you directly to the webpage of software download.
In addition, for documentation related information on each Aruba Switch, please, visit the following site.
http://h17007.www1.hpe.com/us/en/networking/library/index.aspx#.WxgMhFMvyL4
Thank You,
Priyank Patel
Greetings !!
Please go to this link below and you will be able to download the firmware.
https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=J9726A&lang=&cc=&prodSeriesId=
Please let us know, If there is anything else which we could assist you with.
Rahul Dev Sarkar
rahul.dev-sarkar@hpe.com
Contributor II
I always use mnp.arubanetworks.com to quickly and easy find all firmware for all HPE Aruba switches and HPE products.
Cheers
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
You Can download the firmware files of Aruba Switches from below link.
Use a simple trick just change the product number at the end of the link and get the firmware of that that device.
Rohit Singh
Thank you for your help. I will save the link for futures uses.
